what adhesive glue to use - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2013, 12:44 PM
thinking about making my own door panels. what do you guys use as a spray adhesive? Say if I wanted to use some foam inserts and vinyl as the cover?
Old 08-16-2013, 01:10 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Most pros use DAP landau top and trim adhesive, or 3-M spray grade top and trim adhesive. I like the DAP because it is less expensive and works just a s good. Read this Wiki article: http://www.crankshaftcoalition.com/w...ntact_adhesive
One more thing: You will not find this at Home Depot or any other building supply place. You will find it at upholstery supply houses. Try to find it locally, because it can't be shipped to a lot of states.
Old 08-16-2013, 02:30 PM
302 Z28's Avatar
DAP landau top and trim adhesive is absolutely the best. There is nothing that comes out of a rattle can that is worth a s*&^. I just wish my 5 gallon can had not gone bad.
Vince
The Following User Says Thank You to 302 Z28 For This Useful Post:
NEW INTERIORS (08-16-2013)
Old 08-16-2013, 03:46 PM
Do a search for the DAP product and you'll find sources and even a discount code. Additionally, another search will give you quite a few threads on building door panels.
Old 08-19-2013, 01:20 PM
ogre's Avatar
the 'Duracell Project'
i use the regular dap contact cement, but hear the trim glue is better
buy a harbor freight $19 canister paint spray gun and fill it full of contact cement
it will last for yrs without cleaning
i have an old discard spray gun from our shop, the only thing i do to it is plug the vent with a pop rivet in between uses
Old 08-19-2013, 02:21 PM
Wiki Edits: 22
The best bet for a gun to spray contact adhesive with is to use a siphon feed external mix gun with the cup on the bottom. Mine cost $15 from Harbor Freight, has a 2.2MM nozzle and works great. If it ever takes a dump on me, it will be cheap to replace.
BTW, don't use anything but HHR (high heat resistant) top and trim adhesive on your interior unless you like having all come undone in a hot car. YOU CAN"T BUY THIS STUFF AT HOME DEPOT.
Old 08-22-2013, 11:45 AM
due that I live in cali, its hard getting anything over here. has anyone one tried 3m high strength 90?
Old 08-22-2013, 11:48 AM
are you referring to this'? DAP 32 oz. Weldwood Original Contact Cement (2-Pack)-207533 at The Home Depot
Old 08-22-2013, 12:00 PM
Wiki Edits: 22
NO NO NO. You can't buy this stuff at any home improvement store, it is an UPHOLSTERY SUPPLY and is found at upholstery supply shops. This is top and trim adhesive for high heat applications, not what you glue countertops together with. Did you read the wiki article? When you ask a question and you get referred to an article which will tell you everything you need to know, why wouldn't you read it? http://www.crankshaftcoalition.com/w...ntact_adhesive This is what we're talking about: http://www.yourautotrim.com/noname37.html
Old 08-22-2013, 01:00 PM
California is one of the states you cant get bulk sprayable high temp adhesive. 3M 90 will work although expensive, Performance Hi-Temp Trim Spray Adhesive is a good alternative.
Old 08-22-2013, 01:35 PM
Wiki Edits: 22
Performance is about the best aerosol out there, and it's not that expensive. The cans are 16 oz. Performance Hi-Temp Trim Spray Adhesive
Old 08-22-2013, 05:24 PM
thanks.. ya every site says "no shipping to cali" on that other stuff
Old 08-22-2013, 06:30 PM
Newbie37's Avatar
Newbie 37
Last journal entry: Three months since started
Adhesive
I live in cali and i just stopped by a mobile upholstery shop and he sold me some good adhesive. Of course i talked to him about doing a seat for me.
Old 09-06-2013, 04:26 PM
I see you mentioned you're in Cali, where nobody ships DAP to... there's somebody on ebay in socal that had a couple of gallons for sale yesterday, but it isn't coming up now - either they sold out, or the ebay police got them. Keep your eyes peeled though, it could come up again. You could go by an upholstery shop and see if they'll sell you a gallon of it. We generally buy it in 5gal cans, as do most other shops, so a local shop might be able to pour out a gallon or half gallon to sell you, but it may not be cheap due to what they have to go through to get it there in the first place there in commiefornia.
Don't waste your $ on 3m, you will have to redo it again soon. DAP HHR ONLY. Do it once, do it right.
Old 09-07-2013, 02:48 PM
Wiki Edits: 22
3-M spray grade top and trim adhesive is very good stuff in bulk containers used in a spray gun. There is nothing wrong with it, but it is more expensive than DAP.
glue/adhesive to use .. gearheadslife Interior 4 04-11-2013 01:09 PM
So How Much Glue ? Coodeville Interior 4 03-12-2011 11:50 AM
Which glue should I use?? sexypizzaman Interior 6 03-04-2008 11:05 AM
Best glue to use? 39chevy Body - Exterior 2 06-05-2007 06:40 PM
Glue GMCTRUCKS Off-Topic 5 01-04-2007 03:24 PM
