What are the advantages of a gasser straight front axle?
Can a straight axle setup be lighter than a conventional setup with control arms? I figure it is possible. I know it makes more room for headers, any other advantages? Better launch?
The straight axle front ends on the old gassers were done that way mainly raise the front and shift weight for a better launch etc.
An old time gasser friend of mine said he used them for one thing only and that was so he could raise the front of the car and keep the motor low. The rules then were you had to run a hood and nothing could stick up above the hood line. The raised front with the motor dropped to just clear the axle let him run a tall intake with a tall spacer between carb and intake or a later tunnel ram.
Trees |
If memory serves, the center of the crank could be no more than 24" off the ground and thats what it took to get it there. Side effects were lighter frontend, better weight transfer, more caster could be dialed in for better straight line direction, better control of body torque roll and arguably less air drag. Least thats why I did it, Cool was not a factor.
"Fiscus" straight axles are put in almost anything. Im not sure how much of the straight axle you can see. But I have a car in the galley that has 1930 ford straight axle under it. This is the second gasser I built. Its does not have the ride of a Caddy. But its not bad,and they look cool. You can buy anything you need for the axle new. Even a disc brake set up like I have. But remember, lots of guys install them wrong. And it makes the car hell to drive. We can like let go of the wheel at 60 mph and it runs straight. Also after you install it. You have to find someone that know how to aligned straight axle front ends. Most that think they can can't. Its totally different then a late model front ends. I live in a town of over 4 million people and its only one garage that I would trust to align mine. Take your time,and measure twice. If you find it easy your doing something wrong. We also have a 56 chevy car with a straight axle under it. Ill get a picture of it also.
Good Luck ! |
Good info.....My bud is going to put one in a 55Chevy,new front clip(tubing)........
Found Jim Meyers site lot of good info there on 55's setup....... Last edited by kruzr; 02-02-2008 at 06:40 AM. |
Shane |
More reasons ...
They allowed the cross member to be cut away and placed where you want it. That meant you can run headers, motor plates, engine mounts, all sorts of things that are easier to mount or fab. Also, you can drop the pan and service the engine without pulling it. All around tidy front end without the weight of the IFS and massive cross member needed to control/mount IFS.
On the cheap you could get the front end from a pick-up or a van including steering box for a few $$. Better built set-ups used chrome-moly tube axles, coil overs and even disk brakes (although they drag). Many were built with good drums off big GM cars like Buick and the stopped OK. Dollars got you lighter and stiffer. But the ideas were the same
Incidentally, the front suspension of the C/A was stock. http://www.racetec.cc/shope Last edited by BillyShope; 11-10-2009 at 03:59 AM. |
| Dropped front axle questions. | WillysWagon | Suspension - Brakes - Steering | 2 | 01-18-2008 06:51 AM |
| '47-'54 front axle flip!? | suedespade | Suspension - Brakes - Steering | 3 | 04-13-2007 08:00 PM |
| transverse spring & straight axle | 26trackt | Suspension - Brakes - Steering | 3 | 01-18-2003 11:45 PM |
| 34 ford truck front axle ideas and questions | lilred34truck | Suspension - Brakes - Steering | 1 | 10-30-2002 05:20 PM |
| 1938 chev - straight axle front end | WILLARD(SONNY)STOTLER | Suspension - Brakes - Steering | 4 | 12-30-2001 03:26 PM |
