What are the advantages of running a 180* thermostat vs a 195* thermostat? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2004, 05:50 PM
batman09's Avatar
CLICK ON MY AVATAR
What are the advantages of running a 180* thermostat vs a 195* thermostat?Does the engine work harder running a 180*thermostat?thanks bm
Old 09-14-2004, 05:56 PM
lluciano77's Avatar
There are too many varialbes to give a quick and easy answer.
Old 09-14-2004, 05:57 PM
poncho62's Avatar
Wiki Edits: 5
No...it just runs cooler....180 is a good temp to run. You may want a little hotter in the winter when using the heater.
Some engines do run a little better with a hotter thermostat. What motor is it?
Old 09-14-2004, 06:08 PM
batman09's Avatar
CLICK ON MY AVATAR
its a gm 350 sbc crate motor?
Old 09-14-2004, 06:19 PM
poncho62's Avatar
Wiki Edits: 5
180 will be fine.
Old 09-14-2004, 06:56 PM
ya 180 or 195 either or
Old 01-08-2011, 10:44 PM
what should i run in my 383 stroker? i have a 160 right now should it be hotter?
Old 01-08-2011, 11:19 PM
001mustang's Avatar
Heater works better w/ 195F.
Extensive study showed increased engine wear as operating temps dropped.
As I recall, wear started increasing at 180F or so and got progressively worse as engine temps declined.
