What Air Compresssor Oil???
I am preparing a very (>50) old Quincy Compressor for use. I have drained all of the old oil out and need to refill it with compressor oil. It is a 325 ROC 4 Model with Splash Lube.
Any suggestions on what oil to use? I can get Amsoil locally. Would probably need to order most others. Would Amsoil be a good choice? |
i think most compressors use a straight weight non detergent oil
30 weight non detergent oil.. I use the Accell ( not the ignition company ) brand from Walmart. as of this year it is listed as lubricating oil and no longer listed as motor oil
sears , ace hardware, northern tool, easy to find
Thanks for the replies.
I am aware that there are various sources of Compressor Oil, but am wondering if a particular brand/type is superior. I have read that some oils cause carbon buildup faster than others. Lots of carbon in head/on valves when I started working on the Compressor, and would like to delay re-buildup as long as reasonably possible. I assume that most Compressor Oil will work OK, at least in warm weather, but I also assume some may work better than OK. The compressor will be in a side bay of my garage that is not always heated so I would like an oil that also has good performance in cold temperatures. Any specific brand/type suggestions to use or to avoid? |
From the reading I have done, it sounds like 30 Wt ND is what is typically used in splash lube compressors and that you can/should use a detergent oil in ones with pump/filter. The idea being that you want the oil to carry the "dirt" to the filter, if it has a filter, and you want the "dirt" to settle to the bottom of the crankcase and stay there if you don't.
I suspect that most of the synthetics are detergent formulations, but I read about the AmsOil on their website and it says " synthetics fortified with premium non-detergent, ashless additives" so I am thinking I will give it a try. |
| Recent Garage - Tools posts with photos |
| Martin Senour Tech Sheets? | unstable | Body - Exterior | 42 | 03-12-2011 09:09 PM |
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| Runs Like Crap With Air Cleaner On - why? | leejoy | Engine | 30 | 11-16-2010 06:08 PM |
| larger compressor | gburgess2002 | Garage - Tools | 13 | 07-19-2009 09:36 AM |
| More on Orange Peel | KarKen | Body - Exterior | 36 | 03-22-2009 02:18 PM |
