what air pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2006, 06:39 PM
what air pressure
I'm painting with diminsions base and clear and wondering what air pressure and size tip i should use with the trigger pulled. I'm using a gti millinium gun.
Old 02-06-2006, 08:59 PM
You really need to go to the S-W site (click here) and get the tech sheet for the products you are using. The pressure is probably going to be 20-25 on the color and 25-30 on the clear with a 1.4 tip.
Check out the "Basics of Basics" to atomization and setting up your gun in the FAQ pages on this site.
Old 02-07-2006, 07:02 PM
compressor
Thanks for the info. Will a 7hp 60 gal aircompressor 13.3 cfm@90psi be sufficient?
Old 02-07-2006, 08:41 PM
X711
The compressor will cut on, but you should be Ok with it.
"Use 3/8" hose and 3/8" fittings for best air flow !
Custom Air Compressor Guide goleafsgo_12 Garage - Tools 13 03-13-2012 02:10 AM
"Basic of Basics" How do I paint my car myself? Centerline Body - Exterior 5 11-07-2011 07:14 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
Airlines Kevin45 Garage - Tools 22 03-04-2004 04:35 AM
