We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 02-06-2006, 01:38 AM
tiresmoke55's Avatar
tiresmoke55 tiresmoke55 is offline
PO-BOYS-TOYS!!
what all chevys came with a 254 Muncie 4 speed trans?
hey guys
I was wondering what all Chevy cars came with a 254 Muncie 4-speed trans from the factory? I got 1 in my 55 Chevy and I wanted to know also if they hold up good under a beating or not, and are they fine or course spline and how many tooth spline they are.. thanks for any nfo any good clutch suggestion's with a soft pedial?
Old 02-06-2006, 06:11 AM
k-star k-star is online now
muncie
The first gen muncie was produced from 1963 until some time in the 65 model year.It was a 2.56 ratio first gear (i assume that is waht you ment to typ not 2.54) Every 65 muncie i have ever seen has been the first design but i am told there are some of the second design in the 65 year.. 66 started the second design and first gear went to a 2.52
The first design transmissions had a 7/8" pin that the counter gear mounted on with 4 sets of 20 roller bearings. This was not a real heavy duty deal because you could almost get another bearing in each row.. making a smaller load bearing area. the second gen trans went to a 1" pin with 4 rows of 26 bearings closing up the gap and creating a greater load bearing surface,,,
The first gen transmissions also had weaker sincronizer design. This also was corrected with the second gen trans..
First thing is that you need to make sure what trans you have.. look on the side of the main case on the passinger side close to the top will be a casting number it is rasied not stamped into the case... Tell use the last 3 digits...
Then we can go from there...the first design trans can be made to hold up under moderate use, but if you plan on spanking this thing like a 3 year old in walmart you better go with the later transmission...
Just my .02 for what its worth....
Keith
K-Star Automotive
Performance Engines
It's better to have a gun and not need it, then need a gun and not have it.
Old 02-06-2006, 12:16 PM
dgcantrellsr dgcantrellsr is offline
Keith
Don't mean to hi-jack this thread but I got two 4 speeds and the first one has a (case number 3925660 ;2-ring 10 spline input) (serial # P8P12 18N314728)
Second (case3885010) (P1021)
Muncie close ratio 2.20 ????
I used to know a little about these things back in 1965 , But I was better at bangin cogs , and my memory just don't work like a computer any more, matter of fact it never did.
Suffered a lot of brain cell loss during Army years 66-68 and civilian life from 68-present, tough job but someone had to do it
Old 02-06-2006, 12:35 PM
muncie
The first one is a M-20 built in sept of 67 for a 1968 model year
The second one is a 66 or 67, the dates on these years is a bit odd to decipher,, I cannot tell if it's a M-20,21,22 unless i know the ring count,,, then it only holds water if it's a gm input because all the aftermarket parts makers did not follow Gm's pattern...
Keith
K-Star Automotive
Performance Engines
Old 02-06-2006, 07:10 PM
Keith
thanks , Keith
The second one has 1 ring , pretty sure its a gm input; 10 spline;26 teeth on input (m-21 close ratio)maybe ??
Old 02-07-2006, 05:12 AM
trans
yep, 1 ring = M21 if it's still a GM piece.
Is there a 8 digit code some place else on this transmission. It would be in 1/8" tall stamped letters???? It could be on the top of the main case or on either side of the main case....
Keith
K-Star Automotive
Performance Engines
Old 02-07-2006, 10:20 AM
Keith
Found six digits on other side (105274
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "what all chevys came with a 254 Muncie 4 speed trans?"
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 07:45 PM
6 speed manual trans jleolion Transmission - Rearend 1 01-12-2003 10:38 PM
Bell Housing and standard 3 speed trans. 56 Ch Frank D Long Engine 2 11-19-2002 07:46 PM
1968 383 engine w/4 speed trans $950 classiccarprojects Engine 4 05-14-2002 08:07 PM
5 or 6 speed trans 47cnvert Transmission - Rearend 5 03-01-2002 12:08 PM
