what is all the info I will need to order 4.11 gears? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2011, 11:42 PM
adam83's Avatar
I have a ford 9" and 30" tall tires. full spool. There is 3.73 gears in it right now, which were there because before the current engine there was a much more powerful engine in the car. Now, I want to switch to 4.11 richmond gears. I have gone to there page, gone into the ford section, into the 9" section, and got the part number for 4.11 gears (69-0179-1). I am an amateur with differentials, I know some, but Im confused here..
Do I only need to order this ring and pinion set with the part number given, or do I need to make sure of other things first? This is my first gear swap, and I wont be doing the work, but I do want to know what's going on and how to order the right parts.
Old 06-13-2011, 11:37 AM
Wiki Edits: 27
9 in rebuild ?
First you need to do more research... There are lots of magazine articles on the Ford 9 In, utube videos,, DVD's shop manuals ...web info. etc. the parts needed depends on how good yours is, , bearing condition , andy cracks in the case... etc and you will need new gaskets and seals , tools dial indicator.. etc
Old 06-13-2011, 04:44 PM
adam83's Avatar
yep, I've seen (but not necessarily read) hundreds of posts about differential questions, so I didn't think this would be easy. I guess I just got get into it from square one, just like I did on every other system like the engine, suspension and interior.
I didnt think it would be that easy, so it looks like Im either gonna have to learn this myself or go to Randy's Ring and Pinion
Old 06-13-2011, 05:24 PM
prostreet6t9's Avatar
Differential/Driveline
Yes you can order it by that part#. That is the standard/non pro gear set. For the correct brg kit you will need to know what carrier brgs you have and which pinion support you have.
swapping 2.56 gears to 3.50 gears shmiv Transmission - Rearend 9 05-16-2009 09:18 PM
64 Merc cyclinder order/firing order 64merc Engine 1 07-11-2007 08:17 AM
Custom intake tube info (Cavalier, but good info for all) TheVis Engine 11 02-09-2007 04:44 AM
Tranny gears or rear gears? strummin67 Transmission - Rearend 4 06-12-2006 10:17 AM
gears,number of teeth info interceptor429 Transmission - Rearend 5 07-08-2004 09:08 PM
