Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What am i missing in my brake setup?
Old 04-03-2012, 09:37 PM
luckynumberslevin luckynumberslevin is offline
So im loosing my mind on what my problem may be!
I upgraded my brakes on my truck, (62 gmc) from the drum/drum set up to a power disk/drum set up. I used a 79 chevy front clip with brand new brakes, CPP master cylinder, prop valve and a 82 drum set up in the back.. I ran all new lines and new cylinders and calipers. After sealing all my leaks, and bleeing the front and the back for hours i can still easily put my foot to the floor with the brake pedal. I have adjusted the rear shoes tight to the drum and still right to the floor with some amount of resistance. So aside from bleeing and bleeding what am i forgetting or missing?
