What is applied when a 4L60 is in reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2007, 12:44 PM
Billvill's Avatar
Just like it says above I am looking to find out what components are applied in reverse. My 4L60 developed a delay and now a shutter in reverse.
I may decide to build it before I destroy it.
Old 05-16-2007, 01:16 PM
what is applied
The low reverse clutchs and the reverse input drum [ the drum the band applies on ].
And I think your decision to build it, rather than to destroy it, is a good decision.
Old 05-22-2007, 08:51 AM
Billvill's Avatar
I haven't built a box in 25 years. ( I was a Mopar line mechanic at a dealership years ago ) I see there are a ton of parts out there for the 4L60. I have a deep pan and a cooler. I was thinking about the corvette servo. The 9 plate 3/4 pack and the line pressure increase orifice. Last but not least the S10 converter which should give me just a little more stall speed.
Its not a race car but it does have a very healthy 350 in it. I do tow a small trailer with it. maybe 2000 lbs tops. I do like to do a burn out with it once a year at our van club truck in.
Is there anything else I should beef up for a solid rebuild. Should I go for the wide bands and drums along with the good spraug. Where do you draw the line ?
One thing that strikes me odd is that low gear aka manual 1 is solid as a rock. Could the one way clutch be an issue. I wasn't leaning that way because a very slight delay started about 2 months ago. I have to assume it is a hydraulic issue.
Thanks billy
Old 05-22-2007, 09:18 AM
what is applied
Billy what year is this transmission? Lots of things to suggest.
Old 05-26-2007, 06:06 AM
tnsmith10's Avatar
when will it rain???
another thing that it could be that we just found for the same problem is the reverse boost valve, just had the exact same thing, reverse drum and the low/reverse clutches air checked just fine, but i still heard a shuttering noise, through the pump, found out it was the reverse boost valve, and replaced it. (whole pump, didnt have a reamer for the fix that sonnax has. just another idea
Old 05-26-2007, 07:17 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
two different things happening here.
You have a shutter in "R"....... Good holding in "manual 1"
as posted in shifter position "R" the reverse input clutch and the L/R clutch are holding. The "sprag " is NOT holding in "R".... as the sprag does "hold" in "manual 1". The sprag does NOT hold in "R" , so it is not a factor.
You can perform this test: ( as briscoe points out the 'year' of this box can determine how it reacts)
Drive the vehicle to max speed 25 mph.... move the shifter quickly to "manual 1 " as you lift off the gas pedal... Does "manual 1 " quickly take hold and provide engine braking?? IF it delays or seems a bit lazy , you may have a L-R clutch problem. SInce you have a mild shutter problem , this test may show limited results to work with
NEXT:
The S-10 converter for the small V-6 (2.8 liter)engine uses a different input shaft / Spline count setup.
IMHO..... You will not be happy with a S-10 converter behind a V-8 engine.
Old 06-09-2007, 07:07 PM
Billvill's Avatar
Its a 93 4L60E If I accelerate enough backing up my driveway where the rpm comes up raising line pressure I can nail it and there is no shudder. Leads me to think it is a hydraulic issue. I will do the manual shift down test tomorrow. I ran it on a 600 mile trip last week. Before I did . I did a filter and a deep pan. It has about 130K on it and had nothing real ugly in the pan. I had a "corvette servo" on the shelf for about a year and installed it also. That was a waste of my time in that the servo in the box was exactly the same size.
My son in law was backing it up the other day with a trailer on it to move a few things around. He isn't aware there is a problem ( he never drives my van ) anyway he hit it hard in reverse and it spun the tires. Go figure.
I have a core coming and I am going to build one. I would appreciate imput about what goodies to install.
ps: that 600 mile trip was my first highway run with 3.73 gears in the van. That gear and the box in OD is an absolute perfect cruiser @ 70 mph.
Old 06-09-2007, 07:26 PM
smoke's Avatar
This site may give some ideas on what you want.
http://www.4l60-e.com/
Old 06-10-2007, 10:50 AM
Billvill's Avatar
good site ! thanks for the lead
Old 06-10-2007, 11:28 AM
what is applied
Bill this unit has an aluminum piston in the reverse input drum. Once you have it apart, look at that piston carefully. You will see a bleed hole in the piston, where the bottom 'waved' steel plate will flatten out against the piston, when this piston is applied.
Close that hole down in size. When new, this hole may not be a consideration, but, after awhile this hole size, because of many reasons, will let too much reverse oil leak thru, creating a reverse delay, or shudder in reverse.
I would suggest a transgo shift kit, a better sun gear shell, maybe the beast sun shell, a kit that provides the ability to install more clutchs in the 3-4 clutch pack.
There seems to be no end [ relative to parts ] to what you can install into the 4L60e trans, as you strive to make it better. Good luck!
Old 06-10-2007, 12:01 PM
Billvill's Avatar
Thats exactly what I have come to believe. I am leaning toward stepping up to the 4L80. I was talking to Dave Jarvis who drag races a full size chevy van. The truck leaves wheel up and is close to breaking into the 9's with a small block. I asked him what box he was using. He told me it was a bone stock 4L80 with a good converter. If a clean low mile unit becomes available I think i will go that way. If I build a bullet proof 4L60 I could have over $800.00 in parts in it.
Thanks for the input.
Old 06-10-2007, 04:37 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
budget in some extra cash for the conversion to a 4L80E unit....
drive shaft mods , fresh slip yoke, crossmember mods, wire harness conversion , ECM re-programing....
i may have forgotten something
Old 07-31-2007, 07:50 PM
Billvill's Avatar
I have heard about the bleed hole from another builder also. He suggested opening up the separator plate to increase oil flow when reverse is applied. I wanted to install a shift kit no matter what I do so i think I may take that suggestion.
Any Input ? Do you guys know if the Transgo kit maps out the reverse flow hole in the separator plate ?
Old 08-01-2007, 06:09 AM
4l60e
The transgo kit does show you what hole to increase in size [ in the separator plate ] if you are only installing the shift kit and not going inside the trans, to rebuild it.
Old 08-01-2007, 09:31 PM
Billvill's Avatar
I think I am going to give that option a play. The trans just shifts and operates flawlessly in all forward gears. I really don't want to R&I it at this time. If the larger boost valve and opened up fluid feed does not resolve my issue I haven't spent any extra in that I would have added those items to the overhaul list.
4l60 Reverse Only SHOOTISTLB Transmission - Rearend 4 08-04-2007 01:50 PM
Car Will Not Go Into Reverse?? HotRodMan Transmission - Rearend 15 05-22-2007 02:33 PM
Making a reverse shape in sheet metal John Kelly Body - Exterior 4 12-16-2005 08:24 PM
ford aod reverse shift snoman Transmission - Rearend 2 02-17-2004 06:38 PM
