Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What is applied when a 4L60 is in reverse
Old 05-26-2007, 06:06 AM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
another thing that it could be that we just found for the same problem is the reverse boost valve, just had the exact same thing, reverse drum and the low/reverse clutches air checked just fine, but i still heard a shuttering noise, through the pump, found out it was the reverse boost valve, and replaced it. (whole pump, didnt have a reamer for the fix that sonnax has. just another idea
