What auto did this rearend come from?
This rearend is on the 64 C10 I am working on. It has 5 bolt drum brakes. It's leaking fluid and has bad brake lines.....so I need parts but cant determine what to ask for.
Can anyone help me identify it? Thanks Glenn |
Could it possibly be the stock axle?
according to this here its a 12 bolt truck diff. |
The casting number that I can read says "K 287" on the bottom left back side of the center housing. On the front right side it says "GM5'6" and on the front left side is says"NF3896838". Does that mean anything? Thanks again, Glenn Last edited by gotmud; 07-02-2011 at 08:44 AM. |
Waited to long to edit the last post.....The casting number that I can read says
"K 287" on the drivers side- rear of the center housing. "GM5'6" on the drivers side - front of the center housing "NF3896838" on the passengers side - front of the center housing "1207" on the passengers side axle tube Does that mean anything? |
rear end
Definitely a 12 bolt chevy truck rear end, 12 bolt rears were the strongest made by Chevy.
My 64 C-10 has the panhard rod bracket welded to the passenger axle tube.
Might be from a 71 C10. Not sure. Might want to measure the width of the whole thing. I think the 60-66 are a bit narrower than the later trucks NOT the stock axle with a 5-bolt pattern |
There should also be a stamped code on the front of the passenger side axle tube. This wil tell you more Info. http://talk.classicparts.com/showthread.php?t=10431 That NF3896838 Casting # on the center section appears to have been used in several years.
The casting Date is usually something like the *K287*= December/28th/67,77,87. http://www.google.com/search?hl=en&s...7l1734l0.3.5l8 |
Looks similar to the differential under my 1971 1/2 chevy truck. My truck had the coil springs as I guess most trucks that year had
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| Auto Tech vs. Auto Body Career? | mgold | Hotrodders' Lounge | 41 | 01-04-2010 07:36 AM |
| O/D auto for '91 GMC S15 2.5L 4 cyl? | XNTRCI-T | Transmission - Rearend | 9 | 04-24-2008 10:50 PM |
| auto *********** | racingguy | Introduce Yourself | 1 | 08-24-2007 03:03 PM |
| auto | ace_t | Introduce Yourself | 2 | 02-15-2006 03:46 PM |
| 4sp VS Auto | GearHead69 | Transmission - Rearend | 14 | 07-19-2003 04:43 AM |
