What auto-transmission on a 95 Chevy S10? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2008, 05:57 PM
Its got a V6.Th 700 or one of the 4Ls?
Old 02-20-2008, 06:08 PM
runn141's Avatar
SB S10
count number of bolts in the tailshaft housing, if its 4 it is a 700r, 5 or more it is a 4l60.
Old 02-20-2008, 06:23 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the trans is a 4l60E.
there should be an electrical connector on the passenger side above the pan rail . Connector is about 1.25 in diameter.
The 4L60 and 700r4 are the same trans...GM renamed the 700r4 trans to a 4L60
that bolt count for the tail housing would be incorrect method to ID a trans.
Old 02-20-2008, 07:13 PM
I just found an article on them and it says that beginning in 93 the TH700 became a 4L60 with the advent of OBDII.Consequently this newer model would be electronic governed,right? If so,could I change the valve body of a 4l back to TH700 type?
Paulo
Old 02-20-2008, 07:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Paulo
that article would be incorrect too.
in 1993 the 4L60E was introduced into many of the GM rear wheel drive vehicles... primarily pickup trucks.... the corvettes and F body body cars (Camaro) had a non electronic controlled / shifted 4L60 trans with a round 5 pin connector on the drivers side of the trans case
the 4L60E case is completely different in the valve body area... it can NOT be changed to an early v-body from a non electronic 4L60 / 700r4 trans
Old 02-21-2008, 07:45 PM
OK Crosley.The article is on a Car Craft of Nov/07.So by what you explained there were some 4L60s with non-electronic management? Interesting.Governor or not? I will have to check this electrical plug.The idea is to swap into an early car.
Thanks Paulo
Old 02-21-2008, 07:57 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks Paulo
there is confusion here.
a 4L60 is a renamed 700r4 trans. Non electronic controlled.... although the converter clutch is usually applied by the on board computer.
A 4L60E is an electronic controlled / shifted trans. Total different case design in the v-body area. There is NO governor passages for mechanical up & down shifts.... period
A car magazine article?? It has been my experience that these folks are often uninformed , lost , have little knowledge of item they write about.
Old 02-23-2008, 01:45 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
FYI:
A photo of a 4L60E v-body (left) next to a 700r4/4L60 v-body(right)... you can see that they are not swappable .
Old 02-23-2008, 05:39 PM
OK Crosley.Your expertise is super! Indeed many articles published on magazines and books have their problems.We should read them but never take them to the bank.
Tools needed 54 chevy 4 spd auto 57 KINGRAT Transmission - Rearend 3 07-04-2007 11:36 PM
chevy 6 cylinder carb brackets for OD transmission TooMany2count General Rodding Tech 2 09-11-2006 12:22 AM
good site for Chevy S10? Mr.NutCase Hotrodders' Lounge 1 01-29-2006 10:52 AM
choping the top on a 89 chevy S10 Bd Body - Exterior 0 05-19-2003 07:51 PM
transmission rear end for 65 chevy truck shortwide65 Transmission - Rearend 0 05-28-2002 09:37 AM
