What automatic fits a pre 1975 BBC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2007, 10:39 PM
Hi all. Will all modern GM automatics (700R, 4L60-E etc.) fit a 1968 396 big block Chevy? Is there anything special I should know before bolting one of these up? Honestly, this is the first automatic I will own. EVERYTHING else has been a Muncie or Richmond manual trans.
Thanks a million!
Old 02-25-2007, 11:22 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Well I'm getting ready for my 1st standard shift.
as far as I know a Chevy is a Chevy is a Chevy
There are 2 different flywheels or flex plate as far as tooth #'s :168 & 153 I think
Oldsmobile. Pontiac , Buick , Cadillac , Had a different Bell housing
BUT
Some automatic transmissions were Dual bolt pattern
& I've seen the OLDS Pont..... on a Chevy motor with just the 2 bottom bolts & the dowel pins
The 700 R~4 is a overdrive with NO Computer*
The 4L60-E & all that other{NEW}stuff needs computers.*
*{I'm 90% sure about the last 2 so don't hold me to that}
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 02-26-2007, 04:53 AM
I'd first decide how much power you plan to have in the 396. The 700R4, 4L60 (newer version of the 700R4) and 4L60-E (computer controlled) should be able to handle the power if they are built right. However, you could also use a 4L80-E, which is the overdrive version of the TH400. There are kits to use the electronically controlled transmissions in non-computer cars.
If you want a low cost auto transmission, use a properly built TH350 (non-overdrive).
This site is for jeeps, but has some useful comparisons of transmissions.
http://www.novak-adapt.com/knowledge...on_gateway.htm
Bruce
Old 02-26-2007, 11:52 PM
fast68's Avatar
likes chevy trucks & boobies
virtually every rear wheel drive automatic transmission model GM made has been made with the chevy 90 degree bellhousing bolt pattern at some point or another
some were BOP and caddy pattern only though, and some were 10 bolt pattern and would fit all the divisions of GM
for more on this read up on wikipedia.com
lots of good info on this on there
heres one good page on wiki about this:
http://en.wikipedia.org/wiki/List_of...using_patterns
there are other pages of info on this subject on there
read this one about the transmissions models and info on them
http://en.wikipedia.org/wiki/Turbo-Hydramatic
fastest muscle pre 1970 81elcamino Hotrodders' Lounge 86 01-19-2009 04:53 PM
bbc what gears to run.? chevelle4542speed Engine 5 12-07-2006 05:47 PM
402 to a 454 BBC what fits old-bill-t Engine 1 05-06-2006 09:26 PM
crown for king of the muscle cars Quarter mile killer Hotrodders' Lounge 48 08-20-2005 10:31 AM
