What automatic shifter is good - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2006, 07:26 PM
all show, all go with a 383
I'm looking to replace the current shifter in my car, I have a B&M sport shifter and it works fine but I can't utilize my full rpm band of the motor with out shifting the trans manually. The problem is, shifting a non-ratcheting shifter scares me, what if I push to hard and it goes into neutral. My question is, Is the B&M mega shifter a good shifter for a daily driver who occasionlly races, or would you suggest a different type of ratcheting shifter.
Thanks
Dan
Old 02-23-2006, 08:16 PM
shifters
novadan, not sure what the shifter you currently have is, but you can get a B&M shifter with either a gated or ratcheting action. I have the B&M prostick [think thats the name] and I can tell you with confidence I throw alot of force on it from 1st to 2nd to 3rd during a pass. It is a gated shift, full manual, reverse pattern with transbrake. I have never had a problem with it missing a shift, positive lock in every position. Also if you ever do go past 3rd [reverse pattern] and hit neutral at least you won't hit reverse due to the reverse lock out, which is a separate handle you have to move to engage reverse.There are lots of different manufactures and lots of other opinions, this was mine. I'm done.
This is what I'm correcting in the bold print. I have the reverse pattern shift, so it is PRN123. The above description in bold would be for a stock pattern shifter PRN321.
Last edited by mvillewhitey; 02-25-2006 at 10:55 AM. Reason: CSR,oldtimersdisease...take yer pick.
Old 02-23-2006, 10:15 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
auto shifter
I have a hurst pro matic 2 in my nova and love it. I had a b&m megashifter but the handle broke off in my hand one day.Also the t handle snapped in half as well. I ll never use b&m ever again.I know people have used them with no problems but theres hasn't failed like mine.
Old 02-23-2006, 10:45 PM
cboy's Avatar
Last journal entry: Finished
I think all the Hurst and B&M shifters prevent accidental shifting into neutral (or worse, reverse) through either a ratchet or gate mechanism. Even the low end models. The one to look out for is the Mr. Gasket low end shifter. That one CAN easily run right by high and into neutral or reverse.
Always learning...and sharing what I've learned.
crown for king of the muscle cars Quarter mile killer Hotrodders' Lounge 48 08-20-2005 10:31 AM
Automatic floor shifter appy_stables Transmission - Rearend 1 09-24-2003 04:00 PM
Automatic floor shifter for a 76' Ford Truck appy_stables Transmission - Rearend 0 09-24-2003 03:55 PM
Automatic shifter in pickup floor? newchevyman Transmission - Rearend 5 09-02-2003 06:48 PM
putting 68 floor shifter in 67 questions? DeathByGreaser Transmission - Rearend 1 10-23-2002 05:06 AM
