What is the best intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2012, 11:10 PM
I have a 1971 Chrysler Imperial 440 CID.375 HP I run a Carter AFB Competition carb and I was wondering what would the best intake manifold to run. I am replacing the stock cam with a edelbrock camshaft. Thanks Jesse Denny
Old 09-06-2012, 06:02 AM
DoubleVision's Avatar
Edelbrock Performer RPM will work nicely.
Old 09-06-2012, 07:03 AM
Yes, RPM will work nicely. I highly recommend you rethink the camshaft. Edelbrock does not grind cams, they "buy" them. Their offerings are generi-grinds similar to (if not identical) Elgin, Melling, Summit, Wolverine, etc. Comp and Lunati have modern designs that are far more effective (Comp XE series and Lunati VooDoo series).
You're going to need a minimum of 800 CFM, and Edelbrock carbs are "iffy" at best on engines of this size. A Holley is better, and IMO, AED offers the best Holleys modified.
Jim
Intake manifold JG700 Engine 9 07-06-2007 08:16 AM
intake manifold desktop Engine 5 07-10-2006 07:09 AM
intake help?OFFenhauser low pro. ram intake manifold 74chevyflat Engine 0 05-17-2006 07:49 PM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 11:19 AM
intake manifold impala dreaming Engine 2 02-12-2003 05:09 AM
