What is the best method to treat surface rust in doors - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 06-19-2012, 09:54 AM
Riot Racing's Avatar
Last journal entry: Por 15
Originally Posted by deadbodyman
I almost forgot...Heres what I was talking about when we were talking about cutting the inner door so you can gain accessto the back side of the skin..It just so happens I was doing this today to make installing my power locks and windows..
So I started by marking a line through the middle of the door panel holes but first I drilled them out to 5/16 so I could put a few bolts in the holes ,it makes cutting easier and when it comes to temporily putting it back on to see how everything works before you start welding...when the time comes to weld it back on it'll be exactly where it was before you started cutting..it just makes EVERYTHING much easier...
Once the piece is cut and out you can still see the bolts all you do is slip the piece back in and give the nut a turn to hold it tight....You want to be carefull not to cut the hinge supports...That would be bad...I started cutting at the holes then put some bolts in right awayso the piece would stay in place when all the cutting was done and not fall on the floor or most likely my foot..
I stated in my original post and in other post of this thread that I have cut the sheetmetal that holds the door panel to the door. That is easy, however there are still a bunch of areas that I am not able to clean. Your door is much simpler than my door for some reason???
The Following User Says Thank You to Riot Racing For This Useful Post:
stude283 (07-19-2012)
  #32 (permalink)
Old 06-19-2012, 07:07 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Take the skin off and clean both pieces as previous mentioned.
Epoxy prime both halves before reassembly.
  #33 (permalink)
Old 06-19-2012, 07:41 PM
rusthater89's Avatar
But the BEST way would be to seperate the two pieces clean them and epoxy the two pieces then put them back together...It's a lot more work than most are willing to do or pay for so it rarely gets done...I did make a skin seperating tool that allows you to unfold the lips of a skin without distorting the outer skin...Its a pretty simple tool to make, if anyones interested...
They sell that tool at Harbor Freight. I used it to remove the skin from a trunk lid, works well. After blasting and epoxy primer I sprayed eastwood heavy duty anti rust then I just hammered the edges back over.
  #34 (permalink)
Old 06-20-2012, 05:09 AM
deadbodyman's Avatar
Wiki Edits: 11
They sell a skinning tool or the tile nippers???
  #35 (permalink)
Old 06-20-2012, 02:00 PM
123pugsy's Avatar
Wiki Edits: 29
Skinning tools.
I picked up 3 last year when I went to the States.
Name:	IMG_4029 (Medium).jpg
  #36 (permalink)
Old 06-20-2012, 04:05 PM
Wiki Edits: 11
Well lookie there and from HF at that....
  #37 (permalink)
Old 06-20-2012, 07:05 PM
Originally Posted by 123pugsy
Skinning tools.
Yea, that's the one I bought.
  #38 (permalink)
Old 06-20-2012, 07:58 PM
Hey Mike, You hired an attorney yet? Hope your patent is in order.
  #39 (permalink)
Old 06-21-2012, 04:51 AM
Wiki Edits: 11
Actually, I think the Chinese are getting this stuff from the patent attorneys..the Chinese arnt steeling the patents the patent attornnys probably are.
I went through all of this a while back when I wanted to get a patent for a self connecting trailer .I got the idea from watching my neighbor try to guide his wife to line up the ball with the trailer after 4-5 trys he got all pissedoff ,hoped in the truck and promptly put the trailer hitch through the tailgate...I made all the proper drwings and actually built one .I contacted a company that does everything for you they even build them but in the end they get 98% of everything...I didnt think that was such a good deal so I didnt go for it...I'm now wondering if mabee I should, 2% of something is better than nothing.
  #40 (permalink)
Old 06-21-2012, 05:24 AM
67Mustang Al.'s Avatar
You can probably buy these hooked screwdrivers somewhere in China but i had these chewed out screwdrivers so i sharpened the ends into a ball point on the bench grinder then heated the ends and quenched in oil. I hate taking tension springs off as they normally fly off or you end up with pinched fingers from pliers. I call them the "hookalls." They are good for yanking out oil seals too.
Al.
  #41 (permalink)
Old 06-21-2012, 06:43 AM
I had a friend who tried to market a product called a Threshlock. It locked a door by bringing up a bar across the bottom of a door preventing anyone from kicking it in. Anyway the cost of marketing it, applying for patent, AND INSURANCE almost bankrupt him. The product was too expensive and didn't fly. I am one of those guys who just wants to work hard, get paid on Friday and be able to leave it behind until Monday. It is way to late in my life to think about getting rich.
On the other hand I am rich. Just don't have money.
  #42 (permalink)
Old 06-21-2012, 07:00 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Db and 67Mustang Al. and all you other genius inventer types, it would be cool to see those tools added to Home Made Tools (link also at the top of the page).
  #43 (permalink)
Old 06-21-2012, 08:44 AM
My thread got Hijacked by old man banter!
Deadbodyman is a clever guy and is always willing to give advice and help others out.
  #44 (permalink)
Old 06-21-2012, 10:03 AM
Woops. Sorry Riot Racing.
  #45 (permalink)
Old 06-22-2012, 04:47 AM
Posting tools on Home Made Tools .net
Hi 327.
I have taken your advice and have some more home made tools to post on Home Made Tools website. After signing up i thought i would post some pics but do you think i could find where to start. There are only 4 headings there Home,
Forum, Builders and About. I have looked under all headings and found nowhere there to indicate "Post New Tools" or similar. I have missed something obvious there and posted a question there without a reply so.............any ideas.....
Al.
Best rust converters for surface rust John68040 Body - Exterior 38 10-03-2012 05:54 AM
what is best method for removing rust from the entire car andy_s273 Body - Exterior 15 08-02-2009 05:08 PM
How to treat light body rust prior to epoxy birdguy Body - Exterior 7 05-22-2006 08:08 PM
Best method of chassis rust proofing Cruiseomatic General Rodding Tech 9 10-07-2005 11:59 AM
Rust treat inside frame Kramer123 Body - Exterior 3 06-02-2004 10:56 PM
