what is the best position for an H-pipe - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2011, 06:27 PM
I'd like to know if the H-pipe should as close to the headers as possible or as far away as possible still ahead of the mufflers of course
Old 06-05-2011, 06:31 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Click the link these guy's can explain it as good as i can or even better . ? about H-Pipe Installation .
Cole
Old 06-05-2011, 07:59 PM
Irelands child's Avatar
If you are using an 'H' pipe, and it's on a normal street driven car, the RPM range is going to be from idle, 6-800 RPM right on thru the range to whatever your top engine speed will be, i.e. 6500 RPM - occasionally. This would say that it needs to be located somewhere in front of the mufflers. Funny - no, not really as the exhaust gas speed varies as the engine speed. If you were just using it as a race car, basically high RPM, then you could get fancy with the paint, crayon or whatever and find that sweet spot. For a street driven car, locate it where it fits best and interferes with as few other parts. Your performance adder will be minimal and it will attenuate the exhaust sound. My '31 sounds not too bad with Flowmasters and the 'H'. And it's location - where it fits well.
Irelands child
Flexible Pipe from Compressor to Solid Pipe? cab Garage - Tools 24 12-03-2007 07:55 PM
rotor position roy54 Engine 1 03-26-2007 05:30 PM
engine position Charlie57 Hotrodding Basics 3 02-15-2007 10:07 PM
what is beater H pipe or X pipe rale Engine 2 05-17-2006 06:38 AM
x-pipe, h-pipe and other exhaust questions smlblcks10 Engine 7 11-25-2003 06:05 AM
