I think it's pretty much a pain any way you go. I used paint stripper and a blade on mine and it still took a week. The paint got all goopy and sloppy after the paint stripper was on it for a while and made a mess. I found that the large orbital sand discs with some 60 grit or so really rips through quick.... also eats through the body filler good. Atleast it was cleaner but if you apply the aircraft stripper in medium levels around ti and let it dry then hit it with orbital sanding discs it should do the job.
