what is best to smooth body to paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2005, 11:01 PM
I am getting ready to attempt my first full paint job on my car.The car is a 1931 Ford Roadster and has a few places that need smoothing out. Watching tv I have seen them use a material that looks like bondo but seems to be a lot thinner. This material looks like it would be easier to work with. Any help would be appreciated.
THANKS Wiretwister
Old 12-24-2005, 07:00 AM
You are asking a WILD, open ended question. First, are we talking dings, rust pitting, etc.? Or are we talking about "waves" in the body? Or what?
The product you are probably seeing is "polyester putty". Another alternative would be "polyster primer". But I am not sure if you need anything like that.
What does the surface of the metal look like and try to explain more about what you are after.
Old 12-24-2005, 07:05 AM
Wiki Edits: 49
I think what you're talking about is polyester glazing putty. It's similar to body filler, is usually blue in color and is used only to take out very minor body imperfections. It is thinner than filler and sands very easily but needs to be put on in a thin coat.
It's not really what you should use to repair body panels. It's best use is after the majority of body work is done and before the filler primer coats. IMHO anyway.
Old 12-24-2005, 07:17 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Yeah to vague of a question as Brian stated... and the door is wide open with opinions...Just make sure you dont listen to Jim Clark on here... He is a little off his rocker... He may have u using latex paint from walmart and mixing it with reducer
Please dont do what I just wrote... it is only a joke
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 12:33 PM
Is there a place on the internet Overdriv Body - Exterior 5 09-25-2005 06:47 AM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 09:41 PM
brand of body filler, primer, paint to use? montea Body - Exterior 10 03-26-2005 11:01 PM
paint gun deuce_454 Body - Exterior 4 02-04-2004 04:08 PM
