what is the best tire size for a wheel size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2011, 06:25 PM
Well, my title pretty much says it!
I am talking wheels around 17X8, with pretty low profile tires, probably 50 or 55 profile.
I have done a search online but found a variety of very different opinions which end up not helping at all!
Thanks!
Old 11-22-2011, 06:31 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Your honestly going to have to do some test fitting or find someone that has a set pretty close to what you want on a 70 Impala. JMO
is your car lowered or anything ?
Cole
Old 11-22-2011, 06:34 PM
No all stock suspension with polyurethane bushings.
Old 11-23-2011, 08:05 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
it depends on what kind of look you are after
what are you trying to do?
are you just asking about how the tire will look on the wheel ?
or are you trying to find out how it will look on the car?(how it looks in the fender opening)
because the back spacing/offset of the wheel will change how the tire looks on the car
Old 11-23-2011, 11:09 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
There are charts that show what size tire can be mounted on what rim width for best performance..
http://customwheelsmarket.com/rimwheelwidth1.html
Here is one
Sam
Old 11-27-2011, 11:23 AM
I would like to know what will give me the best performance.
Old 11-27-2011, 01:45 PM
Wiki Edits: 3
Rule of thumb for best performance is to match the wheel width to the tread width of the tire..So if your tire has an 8 inch tread use an 8 inch wheel. Of course there is tire compounding to consider as if one is doing autocross one wants some stickies for that but those stickies may not be a good choice for the street as they do not wear well..
Sam
Old 11-27-2011, 03:24 PM
Hmmm, that seems to give very narrow tires, doesn't it? It would mean 205 tires on 8" wheels...
Old 11-27-2011, 03:39 PM
Landshark928's Avatar
FrankenPorsche
The taller the rim and lower the profile, the more the rim should match the tread. With a 17" and a large profile like a 50 or 55, you can go much wider. You should be able to run a 235/45 or a 245/50 with out any issues on a 17x8" rim. Assuming the vehicle allows it.
Old 11-27-2011, 04:01 PM
poncho62's Avatar
Wiki Edits: 5
The rule we used back in the day was to have the tire no more than an inch wider or narrower than the wheel....Not sure what applies with todays ultra low profile tires, but with the short sidewall, I wouldnt go more than an inch wider, thats for sure
Ontario Rodders
Old 11-27-2011, 05:24 PM
eloc431962's Avatar
Wiki Edits: 37
X2 with Poncho.
Cole
Old 11-27-2011, 07:36 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
If these are going on a 70 Impala, you have plenty of room to play with. Here is my 73 running 15x8s with 255/70-15. At full lock turning there was some tiny rubbing on the sway bar from the tread, but you couldn't hear it, nor was it wearing the tire.
By the way, those 15x8s are stock truck rallys
ID:	60233   Click image for larger version
Old 11-28-2011, 09:56 AM
I don't understand?
205 is the center section width, not the tread width
you will need to look at each tires' specs. chart to find out the tread width.
and that is a good rule of thumb (have the tread and wheel width, the same)
the next question is height
when you say "best performance" what type of driving are you talking about?
autocross and drag racing are going to be different
Old 11-28-2011, 02:17 PM
Wiki Edits: 3
The trick is to get a full contact patch of the tire one is using..To give an idea my 31x10.50 tires are on 8 inch wheels and work fine..My 235 tires work fine on a 7 inch wheel and a 205 may be best on a 6 inch wheel. A 275 r60 15 may take a 10inch wheel for best contact patch, of course one needs to get the inflation pressure correct as well.
Sam
Old 11-28-2011, 06:18 PM
Yes, sorry I guess this was a bit vague: by performance, I mean fast, spirited street driving (with the occasional 1/4 mile). Mainly, a fun and fast good weather daily driver.
Tire size vs. wheel size Ratdoggy General Rodding Tech 7 11-11-2009 07:00 AM
wheel and tire size for 70 chevelle Pablo Cusa Hotrodding Basics 6 08-04-2007 05:48 AM
Wheel and tire size help BMM General Rodding Tech 3 09-01-2006 07:42 PM
wheel and tire size for 38 ford stoke46 Body - Exterior 1 02-05-2006 12:30 PM
Tire wheel size 78 monte General Rodding Tech 1 08-29-2003 06:29 PM
