What is the best way to clean a HVLP spray gun? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2009, 04:30 PM
First time painter with a new HVLP gun... what is the best way to clean it after use?
Thanks.
Old 09-01-2009, 05:11 PM
I always swish reducer around in the cup and get it cleaned out then perculate it with clean thinner and repeat the perculating a few times until the reducer stays clean, i only take my gun apart to clean it about once a month or after i spray white ( how to perculate - turn the air down to about 5 psi and take off the cap and barely screw it back on hold a rag tightly in front of the cap and pull the trigger - the gun basically cycles the paint out of the body and cap back into the cup if you hear it bubbling its working if it doesnt bubble check to make sure the cap is barely threaded or up the pressure a couple of pounds - DO NOT PUT THE LID ON THE CUP WHEN YOU DO THIS
Old 09-02-2009, 06:00 AM
da34guy's Avatar
Take it apart!!!!!!!!!!!!!!
Back washin won't get it all out!!!!!!!!!
Old 09-02-2009, 06:11 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
i'm with don. i break down ,clean and lube my gun each time. do this and your gun will always be ready when you are. i rinse with thinner and then wipe it down and rinse with urethane reducer . never leave thinner in it.
Old 09-02-2009, 06:58 AM
302 Z28's Avatar
Break it down and completely clean it every time you use it.
Vince
Old 09-02-2009, 03:01 PM
Thank you. I'll be sure to clean it after each use. Going to use Lacquer Thinner, because that's what I have. Will Acetone work too?
Old 09-02-2009, 04:16 PM
302 Z28's Avatar
Either one will work, but don't leave either one in the gun. After you have cleaned and reassembled it run some reducer through it.
Vince
Old 09-02-2009, 04:38 PM
perfect! thanks.
Old 09-02-2009, 05:09 PM
What Shine and others said. Remember, Epoxy paints harden in most any environment so you must get all of it out of your gun before it reaches "Pot limit time" or you have really got a challenge on your hands. You want to blow air through ever little hole in the gun and look through each one (good lighted back ground) to make sure it is perfectly clean. This includes your pot vent cap. Particularly important are the little holes in your nozzle cap so you will get a good even spray pattern. Even a partially blocked hole will distort your pattern. These are tiny and they become very difficult to clean out if any paint is left in them.
Trees
Why is is bad to spray primer through a exspensive gun? hutcholdschool Body - Exterior 12 01-31-2009 09:19 AM
spray gun tuning help please.. alteredpilot Body - Exterior 6 06-29-2005 09:27 PM
Best Way To Clean A Clogged Spray Gun? way_2fast_4u Body - Exterior 14 05-11-2005 02:46 PM
Titan HVLP 4PC Spray Gun Kit toykilla Body - Exterior 2 05-04-2005 08:16 PM
Decent Remote Spray Gun? starquest Body - Exterior 2 04-26-2005 05:13 AM
