What is the best way to clean rust off of an engine block - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2008, 10:13 AM
coinbandit's Avatar
I just bought a cast SBC factory roller block and it has a fair amount of rust on the top of the block due to the intake being removed. It also has some rust in the cylinders although it is much less there. It will be a bit before the block gets to the machine shop and I want to get the rust off. What is the best way to accomplish this? I have been told that muriatic acid can be used but that seems a little harsh. Also from what I understand, as soon as it is removed, the metal will immediately rust again. While I know rust can be harmful, my main reason for wanting to remove the rust is that I just don't want it on there and I have some time to kill. My plan is to get all the rust I possibly can, and then oil it heavily while it sits. Any and all advice is welcome!!!
Old 11-04-2008, 11:33 AM
Last journal entry: 50 Ply wagon
Take a good ole wire brush to it . Knock off the flaky stuff and then use a wire cup on a drill to get into tighter places. Home depot carries lots of wire wheels for drills. Then just spray it good with W-D 40 and wrap it in a plastic bag.
Old 11-04-2008, 12:26 PM
I use muratic acid for rusty blocks, however, since muratic acid promotes rust, you must immediately wash the block/part thoroughly with water. Thoroughly is the most important part. Scrub out any bolt holes, oil passages, etc. Then shoot some WD-40 or other oil-based product all over to prevent further rusting. You also can bag it (ordinary construction garbage bags work nicely) when finished to prevent future rusting.
My 2 cents.
Old 11-04-2008, 04:36 PM
OHD's Avatar
OHD OHD is offline
After running it through the hot tank, load it into the shot blaster, close lid, turn dial to 12-15 mins, get drink and wait.
Old 11-04-2008, 04:44 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Muriatic acid never stops eating @ metal.
Just squirt some WD on it & put it in a big trash bag.
Let the Machine shop deal with it.
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 05:55 PM
small block engine rebuild 74camaro Engine 2 04-06-2006 05:08 PM
hello my name is justin and i have a question on identifing a engine block. Justin87 Engine 5 12-16-2005 11:15 AM
My 1600 mile engine Kevin45 Hotrodders' Lounge 6 11-21-2005 05:53 PM
how to prepare a block blndweasel Engine 14 08-15-2003 12:28 PM
