What is the best way to make a cowl panel for a 33 pu. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2005, 10:56 AM
powerrodsmike's Avatar
Wiki Edits: 161
I am currently working on a 33 ford closed cab pickup. An unfortunate series of events has given me the opportunity to have to make a filler panel for the cowl vent opening that is much larger than than the original opening. I gave some templates of the curves required to the local custom metal guy with the English wheel. He is having no luck getting the opposed curves required to form this piece. Although the curves are not as severe as a model A cowl, they still seem to present a problem. I talked to 2 other people who said they are familiar with using their own english wheels and they had no suggestion. Is this a panel that is better to make with a hammerform or do I need a better English wheel guy? Thanks for reading this.
BE different....ACT normal.
Old 11-20-2005, 11:27 AM
I seem to remember seeing a prefab replacment piece for your cowl top somewhere. Give a call to some panel replacement suppliers, Rootlieb, Brookville, etc.
How big is this part, the top of the cowl would be very easy to produce on an english wheel. Does this piece needed go out over the lips at the firewall or something?
How about getting another cowl top and swapping it?
Old 11-20-2005, 12:35 PM
Pictures??
How about some pictures.
Old 11-20-2005, 05:37 PM
Randy Ferguson's Avatar
Ferguson Coachbuilding
Last journal entry: '41 Chevy sedan
I imagine it's a reverse curve. Not for the faint of heart!!! They can be a real bear, but a good wheel guy should be able to get it without too much trouble.
My request is right in line with Keith's....send some pics!!
Randy Ferguson
Randy Ferguson
Metalshaping & Kustom Paint
www.metalmeet.com
Old 11-20-2005, 07:58 PM
Wiki Edits: 161
Thanks randy, you are right about the reverse curve. This is what made the 3 metal guys that I have talked to be scared. The hole I have to fill is 21"across X 8" front to rear. A stock 32 roadster cowl patch panel with a filled vent will not work as it is curved outward in both directions. I am looking into whether or not a 30-31 cowl patch panel will work. Also the $288.00 price tag that brookville has on that is a deterrent. I will post some pics tommorrow and then it will be a little bit clearer what I have got to do.. I really need to learn how to do this kind of thing myself.
Metal Finishing, let's talk about it. MARTINSR Body - Exterior 29 04-19-2011 08:47 PM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Metalshaping/Body Panel Fabrication Randy Ferguson Body - Exterior 15 06-06-2005 11:01 PM
Part 2--Metalshaping/Panel Replacement '34 Chrysler fender Randy Ferguson Body - Exterior 1 06-03-2004 07:27 PM
In the exterior boards, someone said i can make my own cowl, how? Rubberman2003 Body - Exterior 4 12-14-2002 11:46 AM
