I just spent most of my day today trying to line up my buddy's 350 with his tranny and then doing the motor mounts. I bought his old motor to use until I can rebuild my 383. Now that we finished his motor I can pull my 383 and put in the 307 i got from him. My 383 is ready to pull and the 307 is ready to drop in. Any good advice on how I can make the install as easy as possible?
I guess that all could be a little confusing. Now that we finished my friends motor Its about getting my 383 out of my '71 Chevelle and dropping in a 307.
Back in the day when my brother was racing a lot we had holes cut in the firewall for belhousing bolt access. Pull out the seat and carpet, break loose the bolts then use a speed wrench, pull out one bolt and when the engine moved foreward tie up the bell to the firewall, we had a 2 x 4 cut to fit under the back of the trans to hold it up to pull the trans mount bolts if it was coming out, then use the jack. the 2 x 4 gave easy access for all the bolts to get the crosmembe out, and we used brass exhaust nuts on the studs,
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
