what is better zz4 or lt4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2012, 07:12 PM
hay guys my name is scott i live in chattanooga tn working on my 1992 corvette i wont two put a hard hitting cam in but dont know which cam two go with the zz4 or the lt4 its got the stock lt1 may be one of u guy have done this and can help me out thanks guy
Old 02-12-2012, 12:06 AM
Last journal entry: update
Using the ZZ4 cam will really help your lower-RPM torque, without hurting the upper-RPM performance. The LT4 HOT cam will have a little of that sound to the idle, people will be able to hear that you did a cam, but it doesn't really beat the ZZ4 cam until around 3000 RPM. From there on up, the LT4 HOT cam will make more power. Typically, 35-45 HP. The LT4 cam will require a mail-order tune at a minimum, but for that combo, there are plenty of good tunes ready to run. You would need a bit of custom tuning for the ZZ4 cam.
Old 02-12-2012, 02:52 PM
Thank's. Hay. What. Kind. Of. Mail. Order tune would. I. Need two. Use. The. Lt4 cam. And. Is. There. Any way. Two. Get. Away. The. Optiy spark. Thanks guys
Old 02-12-2012, 03:22 PM
Old 02-12-2012, 03:58 PM
I have the HOT cam in my ZZ430 Chevy ( from GM )
I have also had the ZZ4 motor ... If I were you I would call the camshaft company of your choice and get them to suggest the perfect cam for your combination and needs. Not a off the shelf GM garden variety cam.
Deuce ... Moderator
Old 02-12-2012, 04:42 PM
That's. Nice. What. U. Putting. It. In.
Old 02-13-2012, 12:10 AM
327NUT's Avatar
"Hay" Scott, why do you put periods after every word???
Old 02-13-2012, 08:53 AM
It's this Dam phone
Old 02-13-2012, 12:05 PM
327NUT's Avatar
HaHaHa.....that must be frustrating as hell!!
