What is this bolt head type called? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2009, 04:17 PM
cboy's Avatar
Last journal entry: Finished
I got these with my Edelbrock intake manifold and just wondered what they are called and what does one use as a driver for them? I'm not going to use them (I got stainless bolts - these are just coated) but I'm curious because I've never run into this head before.
Always learning...and sharing what I've learned.
Old 07-24-2009, 04:40 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
that looks like a 12 point flange cap screw..use a regular 12 point socket on them..quite common in apps where slippage of the drive tool is unacceptable..FYI they are available in stainless from McMaster Carr and I suspect from other suppliers in Grade 8 as well..Not really necessary on a hot rod but they look cool..
Sam
Old 07-24-2009, 04:55 PM
fast68's Avatar
likes chevy trucks & boobies
12 point regular socket is what i always use
same as the clamp pinch bolt on the steering box rag joint assemblies
and on ford trucks 97 and such years crossmember bolt heads for the transfercase and tranny
Old 07-24-2009, 05:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I suppose the three dots represents a Grade 5 fastener, I'm not familiar w/ "08" or "80" (8.8, etc. is metric, Gr.8 is six marks). Anybody?
Anyway, often, a 12-point hex will be a reduced size from what would ordinarily be used to drive them.
The newer SBC head bolts for instance, are flanged 1/2" hex- flanged to better distribute the pressure. They were a 5/8" hex head, non flanged. This was fine for the most part, but did require the OEM rocker arms to be loosened before those head bolts could be turned. Of course, the aftermarket has had smaller heads available- for a price.
IIRC, some U-joints used them, too.
Old 07-24-2009, 05:19 PM
454 Rattler's Avatar
NEVER SATISFIED !!
IIRC= If I Recall Correctly ????
Always wondered what it was.
Thanks for letting me butt in.
454 RATTLER
Old 07-24-2009, 05:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Exactly!
Old 07-24-2009, 06:38 PM
cboy's Avatar
It looks like an 8 or 08 in the picture but under a good magnifying glass it is actually the letters DB. And there are definitely 3 dots under that which I would also assume means a grade 5.
So is it just a matter of going through the 12 point sockets until you find the one that fits?
Old 07-24-2009, 07:18 PM
Last journal entry: More painting pics
This looks like a flanged-head bolt from the Darling Bolt company in Michigan(?). I believe the dots are a manufacturing symbol to trace the foundry where they were made.
Old 07-24-2009, 08:04 PM
cboy's Avatar
That would explain the "DB"
Old 07-24-2009, 08:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Aah- DB not 08- thanks!
I'm guessing 7/16".
6 lug 65 chevy pu jerrybsr Hotrodding Basics 4 06-20-2009 10:20 AM
Head bolt question malibuskier Engine 2 04-13-2009 03:59 PM
Head bolt retorque on SBC? v8hed Engine 28 09-15-2008 08:27 PM
Head bolt sealer T-bucket23 Engine 20 04-11-2008 03:35 PM
chevy 265 head bolt tourqe pattern tomaube Engine 1 10-27-2006 08:21 PM
