what brake fluid? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2005, 07:48 AM
Toms57's Avatar
Last journal entry: More Engine pics
what brake fluid?
I am in the process or putting disk brakes on my 57. Should I use Dot3 or4 or should I use Dot5 brake fluid.
Old 10-23-2005, 07:49 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Iwould use Dot 3
Old 10-23-2005, 08:16 AM
Fast Orange's Avatar
If you are changing all components in brake system,you can go to DOT5.Otherwise,stick with DOT3 or 4.DOT3 and DOT4 are compatible when used together,but DOT5 when added to a system with ANY DOT3 or 4 will react and degrade rubber components in the brake system.
George
Old 10-23-2005, 05:55 PM
The only reason to use DOT5 is if this is going to be a show car and you are worried about the DOT3/4 messing up your under hood paint.
If you have headers near where your brake lines are routed or drive the car very hard DOT4 would be called for. Other wise DOT3 will work just fine.
At any rate DOT3/4 should be changed out once every 1-2 years because it absorbs moisture from the air which reduces its boiling temperature.
Old 10-23-2005, 06:54 PM
Toms57's Avatar
Hey thanks for the input.
brake fluid rally4x4racer Hotrodders' Lounge 1 12-15-2004 04:54 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
When to use Silicone Brake Fluid jpd37 Suspension - Brakes - Steering 4 04-17-2003 06:02 PM
Dot 5 Silicone Brake Fluid?? Yes or No ?? Jim Weeks Suspension - Brakes - Steering 18 04-15-2002 06:22 AM
