What Brand Epoxy Primer under HOK Base? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2009, 10:19 PM
Can I use SPI Epoxy Primer and polyester primer under HOK sealer and Shirmin base? I'm doing the primer and block work and having a professional do the rest.
Should I stay with HOK DP 2000 Epoxy? Does HOK have a polyester filling primer or can I use another?
I was going to use Deltron DPLF primer but I'm unable to get it do to new regulations in S. Cal
Any advice is appreciated.
Old 03-30-2009, 06:23 AM
da34guy's Avatar
Spi is good under anything.
Old 03-30-2009, 07:44 AM
302 Z28's Avatar
Why are you using polyester filler/primer?
Vince
Old 03-30-2009, 03:38 PM
primer
I wanted to use the polyester primer for filling minor imperfections and to block sand prior to the sealer coat.
Old 03-30-2009, 04:32 PM
302 Z28's Avatar
2K primer would be a better choice and much more durable.
Vince
rusty metal primer on clean metal, pine trees and brawling Stroke Body - Exterior 3 06-01-2008 07:29 PM
SPI primer and clear, a product review, and a "how not to" lowROLLERchevy Body - Exterior 26 12-21-2006 06:40 PM
Sealer reaction with primer? TurboS10 Body - Exterior 10 04-02-2003 04:50 AM
