I'm about to get my car going this week and wondering what type of oils I should be using for break in?
The car is going to use royal purple 10w30 full time. But wondering if I should be worried about additives?
The engine is a 385 (will make power from 3200ish - 9000 with a red line of 8300 rpm)
11.88:1
Fully Forged bottom end w/ .0015 clearance on all journals. rings are gaped .028 (1st), .031(2nd) and .016 oil
242/248 Cam @ .050 .584/.579 on 113 separation solid roller. 918 springs. 1.6 roller rockers.
Fuel Injected
Long tubes with true duals flow master super 40s dumped at the rear axle.
High pressure pump and welded pickup in a 7qt pan.'
11.88:1
Fuel Injected
