What Burns Out A Coil? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2010, 06:29 PM
Blue84JeepCJ7's Avatar
I am on my third MSD coil in a year, second in three months. To make a long story short, my engine went nuts today. Felt like I was hit by Anti Aircraft Fire! The tach went nuts and the vac gauge went from 15 to 5 to 15 to 5 to 15 etc. Less than five minutes after it quit, I restarted and it ran basically fine but not great. I switched over to my back-up coil, coil #3, and it now runs normal! Is my Eccel distributor killing my coils?
Old 03-08-2010, 06:43 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Could be the ignition switch or a bad plug wire can cause it also.JMO
Cole
Old 03-08-2010, 06:56 PM
Do you have it wired to a full 12 volts? It should have a resistor circuit that cuts the voltage down to about 9 volts when in "run" and a by-pass circuit that supplies full voltage only during cranking.
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
testing a coil bentwings Electrical 1 09-02-2008 10:22 AM
1991 olds 88 3800 engine coil pack fumplet Engine 28 07-19-2007 01:39 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
Ignition Coil resistance Question Old School Nut Engine 3 06-11-2005 04:36 PM
