What Cam for a 68' LWB Chevy Truck 305?
I cracked my block in my 68 LWB truck...it was the original motor...I know!!
I have a 305 (I believe it's pretty much stock) that I broke down and cleaned up. But I'm wanting to beef it up a tad while I have it broken down. I already have a high rise Edelbrock Intake, 600 Edelbrock Carb, and Headers. I don't have too much money...but I was wondering about a better Cam? I plan on using the same heads too. Any help woud be greatly appreciated!! Thanks guys!! |
The Summit 1102 cam is all you need. If you can afford it I would also get matching springs.
http://www.summitracing.com/parts/SUM-1102/ |
Is that Cam stock or a little above stock?
And would it be 'bad' to use the existing springs??...or can I get away with it? Oh and should I get that Summit Cam as a set that comes with the Lifters?? Or just use my existing lifters? |
When I had my 305, I used the Comp Cams XE268H. It was a good cam.. With the stock converter, I busted the flexplate. It makes decent torque for a little engine. I used the cam kit which came with springs and retainers, port matched the heads and cleaned the bowls out a smidge. Cheers.
Chris |
Nice!
With the advised Summit Cam mention above (which is a Duration 262/272, Lift .420/.442) would it be terrible to reuse the same Lifters, Push Rods and Springs?? Or should I At Least get the Cam/Lifter Set? |
With a new flat tappet cam, you have no choice but to use new lifters.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Ok cool...thanks! I think I'll order that Summit Cam tomorrow then.
Kinda off topic...But have you ever installed a Carb Rebuild Kit on a Edelbrock 600 Manuel Choke? I purchased the rebuld kit today and was gunna try and tackle that this weekend. |
| 1951 Chevy Truck 3/4 Ton shop truck | csparkhurst | Introduce Yourself | 2 | 01-18-2012 11:54 AM |
| 59 Chevy truck body on 80-85 Chevy frame? | texczech | General Rodding Tech | 11 | 08-18-2011 08:24 PM |
| 65 chevy truck to 70 chevy truck frame | Thundrtrucker | Suspension - Brakes - Steering | 4 | 05-27-2011 08:39 AM |
| 350 chevy into 1952 Chevy truck | reeves79 | General Rodding Tech | 3 | 07-07-2007 11:45 AM |
| Small Chevy car wheel to fit Chevy Truck | musky2 | Transmission - Rearend | 4 | 03-16-2004 08:12 AM |
