What Cam is best for stock L31 Vortec 350 heads? 327 Build - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2011, 01:09 PM
Colder2012's Avatar
I am building a 327 (Forged Crank, Forged .40 over Flattop pistons, Roller Rockers, Edlebrock Performer Intake, Holley 600 Carb) I want a choppy/Lopey idle cam that would match up good for these heads, and still run on pump gas. My goal is 350+ HP. Any Suggestions?
Old 06-13-2011, 03:10 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by Colder2012
these heads
Ummm, could you be a little more specific?
Have you figured out the compression height of the pistons you will use? How about the piston deck height? What do the chambers in the heads pour to? What head gasket? How much does the vehicle weigh? What rear gear? What transmission? The cam and converter are the last two items you purchase for a build, after you have figured out everything else. You can't just reach out in thin air and pick out a cam without knowing all the stuff I asked you above.
Old 06-13-2011, 03:39 PM
GMC boogie's Avatar
Isky 264 Mega cam
Old 06-13-2011, 03:59 PM
Colder2012's Avatar
Pistons are 10:0:1, 700R4 transmission, it is in a 92 1/2 ton chevy pickup, tbi to carb conversion. any other suggestions?
Old 06-13-2011, 04:19 PM
Banned
The 264 cam from isky is a good one. I also like the 274h06 cam, which many companies sell, its 218/218 .450/.450 on a 106lsa. Something with about 215-220 duration and a 106-108lsa should work fine for you. I would go with a single pattern up to about 4 degrees more exhaust duration, any more is a waste.
Old 06-13-2011, 04:28 PM
A choppy/lopey idle will not work well with stock gears and a stock stall speed.
And especially bad in a heavy truck.
Old 06-13-2011, 05:48 PM
Heat and preignition
A high stall converter and/or low ratio gears will make your engine run hotter. The hot running engine will drive the knock sensor crazy on the cool aid quality pump gas. The knock sensor will tell the computer to retard the timing in attempt to avoid engine damage.
It never ends, does it?
Old 06-13-2011, 06:22 PM
Hippie's Avatar
Last journal entry: HEI comparison.
From his initial post I'd say the knock sensor and ECM are no longer part of the equation.
How much power can I expect from stock 305 Vortec heads produce? Lil Big Mec Engine 2 03-07-2007 08:50 PM
Singh's Grooves in Ported & Milled vortec heads on stock 350 automotive breath Engine 204 01-31-2007 07:38 PM
Ported & Milled vortec heads on stock 350 automotive breath Engine 23 11-18-2006 02:07 PM
difference between vortec and regular stock heads inquiring_mind2 Engine 2 05-05-2006 10:43 PM
CC chamber of stock vortec heads!!! Johnny 5 Engine 1 03-10-2005 12:45 AM
