what cam do i have - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2012, 08:22 PM
what cam do i have
i bought a 383 stroker the info on the paper work said it was a comp lift was 486/462 any idea which one it is.
Thanks Thumper 33
Old 02-27-2012, 08:45 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If you can't get numbers off the cam, you can measure the lift, but for true specs you need to degree it.
Semper Fi
Old 02-27-2012, 09:19 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Summit Racing has a pretty good filter that lets you sort your way through several different specs fairly easily.
These are the four that most closely look to match what you've given.
http://www.summitracing.com/search/D...h/?Ns=Rank|Asc
