What Cam Do I Need To Make Most Power - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2010, 08:13 PM
Wanna Build My 4 Bolt Main With My Double Hump Heads,they Are The True Chevy 302 Heads,with 202/160 And I Am Gonna Bore The Motor 0.30 Over And Put A 383 Kit,have All New Double Pumper Holly 750 Carb With High Rise Aluminum Intake,double Roller Timing Chain,what Cam Should I Get To Make Most Power,also Should I Put A Roller Roker Set Up Or What?will Be Driving A Lot After Build,also Will Be In 68 Fire Bird Convertible With 700r4 Transmission,should I Put A 2500 Stall Too?waiting To Build Thanks.ps Don't Wanna Bore 60 Because Cant Do Nothing But Sleeve After.
Old 10-13-2010, 08:28 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
You must know the static compression ratio of the motor in order to be able to intelligently choose a cam.
This computation involves 5 values.
1. Cylinder volume in cc's.
2. Chamber volume in cc's.
3. Piston crown volume in cc's.
4. Piston deck height volume in cc's
5. Compressed head gasket volume in cc's.
If you have this information, please post it. If you don't have it, can you get it?
In the end, someone will accurately suggest that you should call the tech at your favorite cam grinder. He will also want to know the static compression ratio and a little more about the car and your intentions before he recommends a cam for you.
Old 10-13-2010, 09:20 PM
BigRoy1978's Avatar
x2 with tech...just call a cam company.
maybe we should stick a topic called "Perfect Cam Choices!!!" Then put in it "call a cam company!!"
Kinda annoying getting on here and trying to weed through all the "Pick my cam for me!" topics and the "350 rebuild!!" questions...people need to do some searching before they post....im dont ranting now lol.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
What cam to get with my current build? havin_a_ball Engine 17 08-05-2010 12:46 PM
oil chevyman420 Engine 19 02-21-2009 11:44 AM
i want to make more power randy24devan Engine 16 01-02-2009 01:00 AM
make more power off a 350 jo5hi3 Engine 5 10-02-2003 07:23 AM
