What cam does my motor have ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2010, 10:48 AM
I am in the process of fitting a 1998 360 chrysler Magnum motor into a project Im building. This was originaly a EFI motor but as this came fron a vechicle that had had a under hood fire most of the EFI parts were toast so I have fitted a new Crosswind airgap inlet along with a Edelbrocck 600 carb and a mallory electronic dizzy. What I would like to know is what cam is fitted to this motor and how well it suits a much smaller and lighter car of about 2500 lbs. The motor was from a 1998 Dodge Dakota RT.
Thanks
Old 08-25-2010, 11:37 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I'm not a MOPAR guy, but did they make a 360 Magnum??? I'm only aware of the 383 and 440 Magnums. Maybe after the 60's muscle car era?
Semper Fi
Old 08-25-2010, 11:38 AM
27 t's Avatar
WHO WHAT ME WAIT I DON'T KNOW.
Last journal entry: Door skins removed
cam specs are as follows
Intake valve diameter 1.925 inches
Cam design type: mild hydraulic roller
Intake valve timing:
......Lobe centerline 115.5
......Advertised duration 251 degrees
......Opens btdc 10 degrees
......Closes abdc 61
.....maximum lobe lift 0.27 inches
.....rocker arm ratio 1.6
.....gross intake valve lift 0.432
Exhaust Valve diameter 1.625 inches
.....Lobe centerline 109.5
.....Advertised duration 261
.....Opens bbdc 60 degrees
.....closes atdc 21
.....maximum ex lobe lift 0.27
.....gross exhaust valve lift 0.432
Old 08-25-2010, 11:43 AM
27 t's Avatar
Originally Posted by 68NovaSS
I'm not a MOPAR guy, but did they make a 360 Magnum??? I'm only aware of the 383 nad 440 Magnums. Maybe after the 60's muscle car era?
yup .. Dakota RT 5.9 250 horsepower and 345 lb.-ft. of torque....
Old 08-25-2010, 11:46 AM
.....closes atdc 21
Thanks for the reply but I belive the valve size you have listed is not correct as I was lead to belive that the inlet valve size is 2.02 ? the exhaust size you have posted up looks right. And if the rest of what you have posted reguarding lift and duration how will that make my car drive as I dont fully understand all that tech stuff
Thanks
Old 08-25-2010, 12:04 PM
27 t's Avatar
Thanks
well IDK.. someone should reply after reading the specs and let you know...
Old 08-25-2010, 01:57 PM
ericnova72's Avatar
More for Less Racer
Just the typical small fuel injection friendly stock cam, it will run with a carb just like it did when it was fuel injected. Smooth stock idle, good low end power, not much over 4500 rpm. No lope at all. Good mileage.
Old 08-25-2010, 02:09 PM
Sounds quite good but I can see myself getting the need for more power after a short while what would be a worthwhile cam upgrade that still is street friendly but will give a good power increase ?
Cam tight on insertion 70bird Engine 12 12-27-2008 07:51 PM
good cam? boatanchors Engine 6 11-19-2008 08:31 PM
roller cam selection for my monte ss redbandit98 Engine 37 06-21-2008 10:39 AM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 10:17 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
