Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What cam to get with my current build?
  #17 (permalink)
Old 08-05-2010, 09:10 AM
turbolover turbolover is offline
Your engine is made of a lot of mis-matched parts, but it will run. A lot of people think that if you pick a low RPM cam and high RPM heads you get the best of both world- in fact you get the worst of both worlds.
For now it is what it is, but you need to decide what you want out of the engine and then modify it to fit that goal. cobbling a bunch of cheap parts together will get a car moving but it will be far from optimal.
