What cam to go with Hyd. or solid (flat tappet BBC) - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2005, 06:16 PM
Bumpstick's Avatar
Hammer and a torch
Copied and pasted spec`s on the engine from one of my earlier post...
Have a BBC 427 (.030 over) forged TRW L-88 (ZL1) pistons that make 12 to 1 with closed chamber heads but am running 781`s (open chamber) so its about 10.8 to 1 and have the larger 2.19/1.88 valves and some bowl and port work... Also the intake is a Performer RPM and BG 750 Speed Demon... It has Hooker SuperComps (35" long tube) with 3" exhaust 2" H pipe and a pair of single chamber Flowmasters The cam is a Lunati 00026 with .549/.558 lift & 232/239 @ .050 (293/310 adv. duration)
Have to change the cam due to a problem with the guide plates and pushrods (have a bad lobe on #5 intake)
So what would be the best replacement for this engine...? 1969 Chevy C10 heavy truck... Has a Turbo 400 w/manual valve body & reverse pattern with a B&M Holeshot 3000... The rear is a 12 bolt w/4.56 Richmond gears & Eaton Posi unit... The intended use is very little street (short trips mainly in town) and mainly strip runs... Maybe 1000-2000 miles per year if that...?
Suggestions...?
Old 05-02-2005, 06:30 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
If your going to run mostly on the strip i would go with a solid cam. You didn't say if your using roller rockers but i would consider that and use a stud girdle.Best to call cam manufacturer and tell them what you intend to use motor for. They will ask you specs on your truck and let them recommend a cam shaft.
Old 05-02-2005, 09:26 PM
firestone's Avatar
http://teamrfc.gospelcom.net
If you have the money for a solid roller that is what I would go with. Below are the cams I would recommend for a solid and solid roller.
Solid
XS274S (236 242 @.050 .568 .578 lift)
Solid roller
XR274R (236 242 @.050 .639 .646 lift)
Either of these cams would work well, If you would be willing to setp up to a 3500 stall, I would recommend going one bump up on each of the cams.
Adam
Poll... on the sound of solid VS hyd cam sound. Blown72Camaro Engine 12 05-28-2004 06:56 PM
What upgrades do you need to run a solid cam? Dubz Engine 9 03-27-2004 09:20 PM
hydrolic lifter cam vs. solid lifter cam chevyelc81 Engine 12 09-09-2003 08:38 PM
flat cam lobe abe Engine 3 01-13-2003 10:04 PM
engine rayjo Engine 3 04-28-2002 09:22 AM
