what cam/intake combo, rebuilding chevy 350 30 over - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 08:06 PM
I have a 350 30 over. Its already built up, but wanted to get a little more out of it. I bought the car with the motor already build, but this winter im going to be putting aluminum roller rockers, new hyd. roller cam, new intake, and probably new pistions (ofcourse all new bearings...etc.). But i just need a good cam and intake combo. The rear end has 4.10 gears and the tranny is muncie 4 speed m22. Not quite sure what size the heads are, but i do know that they are build up and are cast heads. I was thinking of a cam and intake combo around the 2500 or 3000 and up rpm range. i was told that it makes about 400hp or a little more at the wheels and has around 10.1 compression. Any help would be greatly appreciated. Also i would be running it on pump gas and might go for aluminum heads(budget problem). Basically i want to get as much horsepower as possible without out nitrous or forced induction. thanks alot.
Old 08-02-2006, 11:07 AM
nitro_baller4692's Avatar
floppers forever
whats it going in?
i don't think you have 400hp at the rear wheels and if you did why change anything?
Old 08-02-2006, 12:22 PM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
If you have 400 at the rear wheels and conpensating 30% for drivetrain parasitic loss you would have around 530 horses at the flywheel! I agree, why would you want to change anything?
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
Rebuilding a Chevy 350 Chevy rider Engine 2 07-24-2006 09:17 AM
Will my Buick 350 (1970) fit into my 1984 Chevy K10? GFORCECONSTRUCTION Engine 0 05-22-2006 07:58 PM
350 buick in chevy truck? jrm123180 Engine 7 04-03-2004 11:03 PM
