What cam is this? Pics. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2013, 07:18 PM
Slammedsi's Avatar
I pulled a cam out of a motor that I had built several years ago. I'm unsure on the brand, But i do have what i think is a part number. Maybe some one can help me with what i might have here. Ive already looked on all the major bands websites and Googled it several times with no luck.
115835
372593
Then there is a CWC stamped between the drive gear and the last lobe. and a 80 stamped into the front near the front lobe. Any help as to what this cam may be would be awesome. I would asked the guy who built it but he has long passed way.
Old 05-29-2013, 08:30 PM
Richiehd's Avatar
JS-70
"CWC" is CWC Textron, the largest makers of OEM and generic cams.
115835 is some kind of manufacturer code. That number comes up on several different sites when googled.
Bottom number must be some kind of a serial number, Im guessing.
Whos it is? Dunno!!
The Following User Says Thank You to Richiehd For This Useful Post:
Slammedsi (05-29-2013)
Old 05-29-2013, 09:47 PM
Slammedsi's Avatar
Whos it is? Dunno!!
Thanks for the info Rich
Old 05-29-2013, 10:10 PM
BOBCRMAN@aol.com's Avatar
Whos it is? Dunno!!
They only make the cores. Not the finished camshaft..
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
Richiehd (05-30-2013)
been posting work pics, time for toy pics biged04 Interior 2 02-28-2013 07:28 AM
350 bored .060 over... XE268 cam, I didn't put a CAM BUTTON IN!!! Dizturbed One Engine 12 08-08-2010 09:50 AM
Cam bearings 350 chev, cam wont fit in front bearing???? JD's camaro Engine 5 02-07-2008 04:33 PM
Cam: Calculate LCA (cam°) from lobe center angles (crank°)? pgtr Engine 2 09-14-2004 08:28 PM
been busy working....pics.....now more pics and specs matty Hotrodders' Lounge 11 10-19-2002 06:17 AM
