What cam specs work well with centrifugal Superchargers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2007, 01:48 PM
hotrodf1's Avatar
Chasing dreams with a ball bat
Hey all,
I just bought a Vortech V-1 S trim centrifugal head unit, and I plan on boosting my 406 SBC in the camaro via blow thru carb setup at about 5psi for now. Maybe add an intercooler later. The blower is maybe a touch on the smaller side, but I got it for a nice price and I think it will work for what I'm trying to accomplish, which is about 650HP or so at the crank (blower is good to 680HP or so)
I have the goods for a hydraulic roller cam, but I need a new cam to go with the blower combo.
THe motor is a 9.9:1 SBC, Dart Pro1 230cc heads, 1 3/4 headers, single plane intake, 750 mighty demon, T-56 trans, 4.86:1 gears, 28" tires.
So, what kind of cam would work well for this? I was doing some reading, and it seems that a cam for a positive displacement blower should have less overlap than an ideal cam for a NA motor (NA - 108 LSA, blower = 112 or 114 LSA). But, then they said that the cam for a centrifugal would be more like a NA motor, since boost doesn't come in until a higher RPM. So you would use a LSA thats tighter than that for a positive displacement blower.
That makes me think that the same basic cam used on a NA motor, would probably work pretty decent in a centifugally supercharged motor.
Anybody have any good thoughts on this?
ENgine simulator 3.2 is telling me a 222 / 252 cam, 110LSA , on a 108 ICL would give 680 HP at 5.0 psi on the top end at 6000, and 640 ftlbs otrque at 5000.
Would that large of a difference between intake and exhaust duration work very well, or is the program flawed in its "thinking."??
Old 09-22-2007, 04:21 PM
hotrodf1's Avatar
Originally Posted by F-BIRD'88
Something like this Crane Hyd roller Will work well.
A water/methanol injection system will allow more boost, timing and power on pump gas Snow Injection
Ya need to get friendly with one.
I have looked at that cam before. It does look like it would work well.
Yeah, I've been looking at the intercooler vs. water/methanol injection deal. DOn't know what are the benefits of each? I guess the water injection is simpler to install, perhaps a little cheaper, but the intercooler is always there, never has to be filled, and can't just unexpectedly stop working and kabloowy.
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
building a 1935 5 window coupe gunnulf Hotrodding Basics 8 06-28-2006 06:43 PM
Cam Part Number specs Pgraphix Engine 2 05-26-2004 01:42 PM
Work Van needs cam??? Intrepid8 Engine 2 06-03-2001 11:28 AM
