what cam for streetable bbc 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2013, 10:15 AM
I am needing help choosing a good cam for my 65 chevelle 454.
I am unsure about all the motor details because I did not build the motor. Here is what I do know:
Bottom end of motor is all stock with a high volume oil pump.
Head are stock off a 396.
Weiand street warrior intake.
Holley 750
HEI
Headers
dual 3" exhaust with summit turbo mufflers
275/40/17 on rear
Car currently has the stock powerglide. I am looking for a cam that will allow me to cruise around the streets. I will NOT be taking it down the drag strip. I am an easygoing driver most of the time but I do however want to be able to put those annoying rice burner hondas in their place when the occasion arises. Any help in choosing a good cam would be appreciated.
*Note* I do plan to swap out the trans at some point, but one thing at a time right now.
Old 06-27-2013, 11:26 AM
vinniekq2's Avatar
do the trans first if the engine runs well
Old 06-27-2013, 11:32 AM
Currently not an option. My current cam ate a lobe and needs replaced.
Old 06-27-2013, 11:46 AM
vinniekq2's Avatar
if the cam went flat then the engine is coming out. good time to fix all things.next time use a roller cam.Those little imports do very well 0-60,your heavy torque monster is a tire melter so it will be a challenge to say the least
Old 06-27-2013, 03:51 PM
techinspector1's Avatar
Wiki Edits: 326
You will have to disassemble the motor and clean out all the debris and shrapnel left from eating the cam. If you don't do this, you will end up tearing the motor down again shortly because the debris will have eaten the bearings or the new cam that you install.
This will generate an excellent opportunity for you to measure and build to a plan. You cannot match a camshaft to a motor until you know the static compression ratio anyway. Call any cam grinder for a recommendation, that's the first thing they will want to know, the static compression ratio.
Now, wipe that smile off your face, get your tools out and get busy.
« ls2 | headgasket »
Cam selection... 383 chevy, vortechs, heavy car...streetable but fun. 400hp-ish Motochris Engine 20 12-13-2012 04:42 PM
383 Cam Swap. Thoughts? More Streetable... V8 Super Beetle Engine 35 10-26-2012 01:28 PM
Building a STREETABLE BBC for spray nskyline34 Engine 9 10-23-2012 08:51 AM
I think I've chosen my cam- 454 bbc. Tell me if I'm an idiot fourspeedwagon Engine 4 05-11-2012 10:53 PM
BBC 454 - Cam Selection - Solid vs Hydraulic - Help me Choose leejoy Engine 1 11-11-2007 05:45 PM
