What Cam To Use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2007, 03:00 PM
What Cam To Use?
I Have A 351 Small Block And Am Wanting To Give It A Little More Umph. Without Having To Change Every Internal Part. Any Suggestions?
Old 08-13-2007, 03:48 PM
Why do you capitalize every word in your post?
What year and car is this 351 in?
I could suggest something like a 4bbl carb,.....But, if it's already fuel injected........
Old 08-13-2007, 03:56 PM
The 351 Is In A Ford Truck,and Its A '94
Old 08-13-2007, 04:35 PM
Your 94" Ford could have came with a roller, or flat tappet cam......Vin H for the roller, and vin R for the flat tappet.
The flat tappet cam specs where 198*/208* @ .050", .416"/.445", 114.5LSA.
The roller cam specs where 176*/197* @ .050", .421"/.447", 115.5LSA
Where do you want more "Umph"?
If you have a roller motor, a used Mustang 5.0 cam off Ebay might be the hot ticket... Dan
Old 08-13-2007, 07:09 PM
Changing cams
Where would the H or the R fall in the vin? Cause my vin has both an H and an R.
Old 08-13-2007, 07:18 PM
techinspector1's Avatar
Wiki Edits: 326
You're starting at the wrong end of the truck. Shorter ring & pinion first.
Old 08-13-2007, 08:13 PM
Different cam, headers and gears.
Old 08-13-2007, 09:16 PM
Your letter code should be in, about the 8th spot.
Go here to decode your VIN...... http://www.fordf150.net/howto/decodevin.php
And here to figure your axle ratio from the sticker in the door.
http://www.fordf150.net/howto/decode.php
You may find that you already have a 3.73 and limited slip in the truck.
Then again, you may have a peg leg and a 3.08 gear. If that's the case, techinspector1 is giving good advise.
My guess is that you have the roller cam with only 176* of intake duration.....A Mustang roller has 210* on both intake and exhaust. Very mild in a 351, yet it'll wake it right up in the mid range.......Dan
Pontiac cam? Wmarden Engine 12 08-22-2010 09:09 AM
Is it possible to degree an unknown cam? Scrumgees Engine 4 03-18-2006 12:50 PM
87 octane engine cam swap? 71C10 Engine 6 01-20-2006 11:50 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 02:11 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 12:51 PM
