What Cam to Use - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2012, 11:30 AM
What Cam to Use
I am planning on rebuilding a 3.0 V6 Ford Ranger motor with 200,000 on it and was wondering what cam i should use i know there are dozens of cams out there but not sure what one would be the best. And another question should I get it bored out while I am at it.
Old 02-04-2012, 11:59 AM
techinspector1's Avatar
Wiki Edits: 326
The motor as it was produced at the factory, was fitted with the proper camshaft for the static compression ratio and the work that the motor was designed to do. Any other camshaft will not work better in your stock motor. It takes associated parts to make a hotter camshaft work, you cannot just stick a hot cam into a motor and expect better performance. You have to match the cam to the static compression ratio and the intended use of the motor, oftentimes you will have to also change the converter stall speed and the rear axle ratio to make it work right. My best advice.....reinstall a bone stock cam.
Have your machine shop technician measure the bores of the block to see if they need to be bored for larger pistons and rings.
