what cambo is beast whith my 383 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2009, 04:57 PM
what cambo is best with my 383
hi my name is justin i need help i have a 383 sbc and im trying to get the most hp out of it i can at a cheap cost
i have cast iron vortec heads
950 holly 4 barrel
so far and have no clue from there
does anyone know a good combo to get close to 500 hp or more don't no much about cams and my heads but i do no thats where the power is
Old 12-08-2009, 05:17 PM
wretched ratchet's Avatar
one full turn after it squeeks
Welcome, Justin, I think if you will post this question in the "Engine Thread" you will get more responses - - - good to have you onboard.
Old 12-09-2009, 03:20 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site.
Cole
Old 12-10-2009, 11:02 AM
those vortec if there 100 percent stock will take need some work to accept a cam with more then 465 lift or so, and if you want 500 hp most of your performance cams are going to have lift higher then that, i think you might have to get those vortecs ported to make that horsepower numbers to but im not to sure, what kind of car is the motor going in and what kind of gears do you got??
Old 12-10-2009, 12:23 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i've posted this on here before just recently but bare with me here i go again.
this is the motor i have in my 87 camaro:
350 4bolt main @ .040 over, decked .025, scat 9000 3.75 crank, KB 18cc D dished pistons, eagle SIR 5.7 rods, clevitte bearings, arp main, rod, and head bolts, pistons @ 0 deck, dart platinum stg 2 heads that have been cleaned up gasket matched and shaved to 60cc, solid cam with 282/290-240/250 @ .050 .560" adjusted lift from 1.6 roller rockers, victor intake angle and gasket matched with 1" spacer, 850cfm holley DP. compression is about 10.2:1
computer sim says 522hp/ 500tq
it's in a 3500lbs car, runs of high octane pump gas, newly built and i haven't really got the car completely tuned yet for the track but the last time at the track i was running 11.7-11.8 at around 116mph. i should have some faster times based on MPH, it should go 11.4-11.5 with some more tunning and practice.
not real sure if you are going to be able to get the 500hp mark out of the vortecs, i know it's been done, but you will need the perfect set up. with some port work the vortecs have been known to get around 240-250cfm @ .550" i think it would be a little more realistic to expect around 420-440 from the vortecs. but they do have excelent combustion chambers "fast burn" that are very affective.
what is the intended use for this vehicle, what is the vehicle, what kinda budget are you on, tire size and rear gear ratio would all be helpfull info
Old 12-10-2009, 12:46 PM
Banned
intended use is very important. 500hp in a street car is not as fun as it sounds. 500ftlbs doesn't mean much in a race car though... Look at where you'll spend 80% of your time and design for peak average power in that area.
a street car would be about 2,000-5,000 RPM. A race car would be about 5,000-7,000 RPM. You may be somewhere in between.
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 08:16 AM
A 2.5 ton beast and a 383 stroker... what tranny and rear end? Drewnashty Transmission - Rearend 7 02-21-2006 11:52 PM
What makes a 383 so much more expensive? Chevy21 Engine 12 09-30-2004 08:55 PM
383 nitrous powered beast...suggestions? fireforsin Engine 1 10-17-2002 04:57 PM
