what can I do to a ford 300 6 cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2008, 08:30 PM
I got a 300 6 cylinder and I want this thing to scream besides taking it to a machine shop and does anybody know where I can buy a alluminam head for it.
Old 10-08-2008, 08:39 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Here's a start
http://www.cliffordperformance.net/
http://www.alanjohnson.com/ajpframe.htm
Old 10-08-2008, 08:52 PM
Wiki Edits: 31
Classic inlines has the best selection for Ford I6 hop up parts.. Mike ( the owner ) is working on an aluminum 240/300 6cyl head, probably see them sometime around august for sale. he arleady has had an aluminum 200-250 cyl head produced for over a year now... Clifford performance can only dream of Mikes selection.
www.classicinlines.com Mike is a stand up guy also, if your dealing with that company, your dealing with him personally.. I'v spent over $2,500 at 1 time from his company, and I'd spend another $2,500 if I was doing another 6
Old 10-08-2008, 09:13 PM
what about this
On clifford 6-8 theres a thing called a triple drought intake. I know the carrberater sets on the engine and it sucks fuel and air into the cylinder. but that triple drought intake is got some like miniture cylinder like things on it, and how does this thing work
Old 10-08-2008, 09:22 PM
Wiki Edits: 31
what you are seeing is a assembled side draft manifold.. the manifold is sold without carbs. you need 3 Webber DCOE carbs, linkage and 1 of there headders to make it work.. a single 4bbl won't look as cool, but it's not going to cost you $1,000 to put on ither.. the side drafts really arn't good for a truck application IMO.
Old 10-08-2008, 09:37 PM
Cool
that side draft is it whats shooting the fuel in or air what exactly is it doing, and I didn't know you was from pratville I live in thorsbyAL . Is the body look any good on your falcon or have you done sold it yet matt167 because it sounds interesting.
Old 10-08-2008, 10:11 PM
Wiki Edits: 31
I live in Prattsville Ny... I havn't sold the Falcon yet, but you'll have to PM me for details to comply with forum rules.
the side draft carburators mix the gas and air, just as any normal carb works
Old 10-08-2008, 10:14 PM
ahhhhhhhh
What do you mean pm for forum rules.
Old 10-08-2008, 10:17 PM
Wiki Edits: 31
forum rules say that I cannot discuss my classified ads on the forums.. you have to PM me for details on the car, to be in compliance with the forum.. otherwise the mods will just erase any of those posts anyway
Old 10-08-2008, 10:22 PM
sorry
I didn't know that sorry, hey one more thing before I go to bed ON alanjohnson.com theres a alluminam head for a 4.9 wonder how much more HP it would give me on a stock 300.
Old 10-08-2008, 10:40 PM
Wiki Edits: 31
just the head is probably a 10-20% gain.. 37cc chambers means the compression might become too high for pump gas ( IIRC the stock head is around 60cc ) . you would need a set of pistions with a large dish, and it could throw quench and squish off. assuming 60cc chamber is stock.. you would need to add 38cc of volume in the pistion to maintain stock compression... you could put the pistions .050 in the hole using custom pistions with a stock dish ( 10cc ) and that would bump 20cc but it would be all kinds of screwy doing that, and it wouldn't run very good
Old 10-08-2008, 10:46 PM
what can I do to a 300 6 cylinder
We'll I don't know the compresion is already like 6:1 or 7:1
Old 10-08-2008, 10:55 PM
Wiki Edits: 31
Factory 300 I6 compression has always been above 8:1.. '71 or older and your looking at 9:1 or so, and '80 or newer and it is likely 8.5:1... cutting compression was the way to de smog cars in the 70's. better cats and emission devices came in the 80's and comp ratios were increased again
Old 10-08-2008, 10:59 PM
hey
hey I'll have to talk to you tomorow I got to go to bed its midnight here in ALABAMA, and thanks for every thing
Old 10-09-2008, 09:12 PM
to be in compliance
Comply, Obey.
RUCK FULES!
Go get yourself a 4 bbl intake manifold and carb. Don't forget the camshaft!
ford expedition #1 cylinder 59 wagon man Engine 5 11-12-2007 05:48 PM
Would unequal drums cause a brake cylinder to not fully release? heel&sole Suspension - Brakes - Steering 2 03-29-2007 06:47 PM
Ford 300 oil leak swellwelder Engine 3 08-28-2003 08:34 PM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 03:38 PM
Decoding Ford 300 6 tag on timing cover Duner Wi Engine 3 02-06-2003 11:36 AM
