What can i do to keep from spinning my tires at launch - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2002, 07:42 PM
Angry What can i do to keep from spinning my tires at launch
I have a 1968 Chevy C-10 Stepside it is all stock rear susp. and i am traying to build a low budget weekend racer
Old 12-12-2002, 08:04 PM
Post
you might try an airbag on the right rear, traction bars and a little less tire pressure when you race.
Old 12-12-2002, 08:17 PM
BOBCRMAN@aol.com's Avatar
Post
the rear suspension design of that chevy truck is not even close to being a good drag setup. About the only thing you can do is put the biggest slicks your motor can handle under the truck. if it spins let air out, if it bogs add air.
