What can I do to make my 1985 Chevy Chevette run better? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2003, 12:27 PM
New Member
Post What can I do to make my 1985 Chevy Chevette run better?
I recently bought a 1985 chevy chevette for $400 (really good interior..and only 55k miles). I am using it for delivering pizzas part time....however, once I sell my 2000 honda civic, it will be my primary car for at least 5 months, so I need it to run decent. The car has problems starting every once in awhile...and it failed smog. I bought the car at a thrift store, so they didnt tell me a whole lot about history. What are some things you guys recomend I do (short of rebuilding the engine)? Im no car pro...so keep that in mind.
Old 03-27-2003, 01:11 PM
Tazz
Post
Ok this is a for real question, so here. Change the oil and the oil filter then take it in for the e-checks. Put a new air filter on it and run a little high octane gas in it before you take it to be tested. It should have clean oil, good gas and be warmed up before tested. Good luck, I ran one of these for work for a couple of years, I liked the gas mileage. The shove-it got me around and was good in the snow.
Todd <img src="graemlins/mwink.gif" border="0" alt="[mwink]" />
Rat Rods Rule!
Old 03-27-2003, 01:29 PM
Post
it might help to dump a can of restore in it a few days before you take it for its next test,could help bring down blow by,i had one of those too.i drove the hell out of it and the only problem i had was with the starter.
Old 03-27-2003, 05:09 PM
New Member
Post
I was thinking about changing the spark plugs too. The manual says it needs plugs with a .035 gap. Does that mean I only need to find a plug with that gap? Or are there any other things i need to worry about with spark plugs?
edit: I just looked up some NGK plugs online, and they recomended .045 v-power or platinum plugs. Is that because they dont make .035 or what?
[ March 27, 2003: Message edited by: '54-Hunter ]</p>
Old 03-27-2003, 06:20 PM
kitkar's Avatar
Wink
If U don't have any luck with the platinun plugs, try deisel plugs. Volkswagon or Volvo plugs should work nicely. Just remember to regap 'em to .035".
