What car Did This Seat Come Out Of - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2010, 05:32 PM
rollenhard's Avatar
What car Did This Seat Come Out Of ?.
What im trying to do is get the headrest out any help would be great
Thanks
Old 08-25-2010, 05:46 PM
ericnova72's Avatar
More for Less Racer
Looks like 78-87 GM metric car-, Buick Regal, Olds Cutlass, Pontiac Grand Prix, Chevy Monte Carlo, Malibu, El Camino. Fabric and shape pattern specifically looks like Regal or Cutlass. Not sure how headrest comes out, CRS, I think you just push headrest to the side or center, to make the center post lean over and it comes loose, might be a lever you have to trip also right at the top of the seat at that plastic moulding around the post.
Old 08-26-2010, 10:17 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Eric is right about the cars it could have come out of. You need to slip a flat piece of metal down the front of the flat metal piece that is attached to the headrest. This will disengage the headrest, and it will come right out.
Old 08-26-2010, 10:23 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A clean "de-toothed" hacksaw blade will work if you don't have anything else to use. Tape the end so it doesn't mar the chrome.
Old 08-26-2010, 10:40 AM
Wiki Edits: 22
The hacksaw blade is a good idea. Here's what I use. It's a piece of flexible spring steel made into a headrest removing tool. Just push it all the way down and pull up on the headrest, it will come right out. The headrest needs to be disengaged from the spring steel stop that holds it at the holes in the headrest shaft. This headrest was from an '86 Cadillac.
ID:	47706   Click image for larger version
ID:	47707   Click image for larger version
Old 08-26-2010, 12:08 PM
rollenhard's Avatar
Thanks for the help guys how far should the hack saw blade go down i only can get it to go 2 1/2 inches is that enough ?
Thanks
Old 08-26-2010, 12:33 PM
Wiki Edits: 22
Pull the headrest up as far as it will go. Push the tool down next to the shaft of the headrest and you will feel it hit something. Push it down a little farther, about an inch or so and that should release the headrest.
Old 08-26-2010, 01:08 PM
rollenhard's Avatar
Got it out thanks for all the help guys
Case Closed
Painting a Metallic in pieces Polish Painter Body - Exterior 18 09-11-2010 07:16 AM
Seat belt mounting points in glass car rod kent General Rodding Tech 29 01-30-2009 11:11 AM
Re-padding an old car seat. DanTwoLakes Interior 9 09-23-2008 07:52 AM
What's a good timing curve for a 4100lb car? Malibu73 Engine 3 03-04-2006 01:51 AM
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 09:57 AM
