what car should i look at for a 8.5 10 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2005, 10:29 AM
malibu68's Avatar
hello, i found out that in my 68 chevelle malibu i have an 8.2 10 bolt and for my application it just wont due, i was told the best thing to do was to find a junker 8.5 10 bolt and a posi unit, i need to know what cars would be ideal, preferable that would fit into my chevelle without mods, ( coil over) not leafs. i think i will go to the junk yard and try and track this stuff down but im not sure what cars to look at for a 8.5 10 bolt, without or preffereable with posi so i dont need to buy it. Thanks alot, Marc
Old 03-25-2005, 11:47 AM
Stupido1's Avatar
74 NovaSS
i am pretty sure that all 70-74 novas have 8.5 10 bolt rear ends. And there are tons of those.
Old 03-25-2005, 11:59 AM
malibu68's Avatar
is that a leaf spring rearend? of coil overs
Old 03-25-2005, 08:33 PM
Novas have leaf springs & the rear ends won't fit, although internal parts from the pre-89 8.5's can generally be interchanged. A '68-'72 A-body rear end should be a bolt-in, but not all of those had 8.5's. I think Malibus finally got the 8.5 in '72, maybe earlier but I'm not sure. Look at the photo of the 8.5 & notice the heavy triangular protrusions at 5:00 & 7:00. Sometimes these protrusions look like somebody drilled a big old hole in it so there's just a partial projection left.
Here's a site with some ID info, & a couple of rear ends to avoid:
http://www.oldsmobility.com/10bolt-tech.htm
You may need a "conversion" U-joint & a slightly shorter driveshaft.
8.2 or 8.5 10 bolt? 71rsz28 Introduce Yourself 1 02-15-2005 07:33 AM
10 bolt vs. 12 bolt. Iwanttolearn Transmission - Rearend 4 02-05-2005 10:32 PM
12 bolt with 10 bolt carrier? JamesRS Transmission - Rearend 3 01-17-2005 08:59 PM
10 bolt ring & pinion waynedawg Transmission - Rearend 1 07-20-2003 07:59 AM
