What carb and intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2006, 08:05 AM
I have a mild 327 ijust rebuilt it has 305 58cc heads, performer cam 112 lobe sep. 1 5/8 long tube headers. Car is in the 300 hp range, i started with factory Q-jet intake and 750 Q-jet Then went with 600 holly then holly street dominator 300-36 with 600 holly. Car has 373 rear gears, i built this car to have good bottom end. It just does not pull hard as i want. I have a 70 mavrick grabber 302 good size cam FMX tranny 410 gears 2 barrel carb, it will damn near pull the front wheels. The chevy is a 73 nova 350 turbo with B.M. shift kit any ideas thanks Wormy.
Old 05-04-2006, 08:54 AM
In my opinion, the 327 is a high revving engine and was designed to be just that. A stock 327 is a 4.00" bore with a 3.25" stroke as opposed to a 350, same bore 3.48" stroke. The 350 will give more grunt down low in the rpm range due to increased stroke. A 383 (3.75" stroke) will be a torque monster right off idle.
The low rpm torque of the 327 (the problem you mention) has always been a problem for a street car, but it will SCREAM once you wind it up!!!!
Old 05-04-2006, 09:35 AM
you answered your own question,
the grabber has a 500cfm? carb, and the stronger cam, slightly deeper gears, and (?) weighs less than the 327 car helps alot
some of the carb mfgr's sites used to have cross references for carb size/motor cube selection, check them out, I would expect they will be about 500 cfm if is low end torque is what you want from higher Hg and velocity
Old 05-04-2006, 09:50 AM
The 327 wasn't specifically designed as a high revving motor, it was also a mid-size V-8 offered in passenger cars and trucks during the 1960's and into the 1970's. The 0.23" increased stroke of the 350" motor adds torque but not anything out of the ordinary.
Have you done any dyno or strip testing of your Nova? The fact that your Maverick runs good has little bearing on the setup of your Nova. What are the rest of the engine and chassis specs on the Nova?
Old 05-04-2006, 03:17 PM
I am building the nova for my wife, car is pretty much stock just added gears, slapper bars,the shift kit, The motor was a 66 2 ton truck motor i have had for about 10 years it only had 30.000 og. miles i rebuilt it stock no ridges bore was good honed only, the rest is stock except as stated above. Has 50 lb oil pressure at 600 rpm hot cam is not wild 420- 442 it just seems to need somthing, Motor has about 100 miles since rebuild im not looking for a 12 second car just a good running street car.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
Intake Manifold and Carb Ozz1967 Engine 9 12-29-2005 12:34 PM
Performer RPM intake & carb Q MegaTherion Hotrodding Basics 1 09-14-2005 04:13 PM
HELP cam, intake, carb 64 nova Engine 9 07-12-2005 10:39 PM
Stipud ? Maybe/Need help determining my Carb and intake ArchonRacing Hotrodding Basics 8 01-15-2005 06:03 PM
